Tape measure tool real time dimension box is not showing up?
Have been using SK UP 2019 then switched to 2020 & noticed that the tape measure tool is not showing the little box which shows the real time dimension as you drag a guide line. I’m I missing something?
In '19 it works great. Did SK Up get rid of that?
David E/ Staying at home in Hawaii
Do you mean like this?
It’s not gone but your installation may have set the display state incorrectly. If I remember correctly you can edit the SharedPreferences.json file to fix it. Find ShowInferenceTips and change it to true.
I think you should find SharedPreferences.json in User/Library/Application Support/SketchUp/SketchUp 2020/SketchUp. That’s from rusty memory, though.
Thanks for the info Dave, I tried it but it wouldn’t let me change it.
David E
It may be that the OS requires you to set permissions to edit the file but it should be editable in a simple text editor. I had to do this in SU2019 for one of my computers but that was on Windows.
Out of curiosity, is ShowInferenceTips set to false?
Yes it is, I’ll try with “Text Edit” app.
David E
Looks like that worked. Thanks a bunch. Appreciate all your input to this forum & love your work!
David E
Perfect! I’m glad to know that worked.
And thank you.
FWIW I sent you a PM.
Hi There, having same issues but didn’t really understand this method. But now I’m using 2025 version
Hei Michael. So you aren’t seeing the Measurements window? Try this: go into View>Toolbars. Tick the box for Measurements. Does it show? If it was ticked, untick it. Does it show in the lower right corner?
If that doesn’t work, is it possible that the bottom of the screen is just hanging below the taskbar or off the bottom of the screen?
Thanks Dave :slight_smile: You’re always solving my issues..:star_struck:
You’re welcome! Which part fixed it?
was the measurements tix box :slight_smile:
