I’m trying to save a layout file in an older version, but the SketchUp layout labels don’t turn off when I save the file and open it again. I need to save in an older version.
MODELO 5X10.layout (3.5 MB)
What older version are you saving the LO file to? If you are saving to a version from before tag control was available in LayOut you will lose the settings since that’s not supported in the older version. You would need to set up scenes in the SketchUp model with the tags set as needed and use those for the viewports. And if you are saving to a version before dash styles were supported, you’ll lose the dashes.
I’m trying to save in version 2018, but I tested and the oldest version I can save is 2020, thank u
Again, if the feature isn’t supported in the older version it’ll be lost when you save to that older version.
