Sunlight not entering model
Hello- I am trying to model on sketch-up and for some reason the sunlight is not entering into the model. I have tried adjusting the shadows, sunlight, adding a dome light… I feel like I have exhausted the options. The file is too large to attache but, here is a screen shot showing my issue. I have even deleted out the glass in the windows. Just a couple of days ago I was not having this issue.
Screenshot 2023-06-01 at 12.00.33 PM
. It’s been 3 days of trying to figure this out…
Share the SketchUp file so we can see exactly what you have set up and get you sorted out immediately.
It says that my file is too large.
Upload it to DropBox or WE Transfer and share the link.
Hoping this works!
That worked. How was your model created? It’s a mess with a lot of triangulation that shouldn’t be needed. I turned on Shadows and set the time and date as shown. The sun enters the building as expected.
By the way, it would be a good idea to clean up your model. Fixing all that triangulation would be helpful. Also correct tag usage.
Screenshot - 6_1_2023 , 1_47_50 PM
Purge unused stuff and reduce the size of materials and simplify the entourage components. After purging and reducing the largest texture images the file size reduced by 49%.
After you clean up your model (Dave already told you what and how), try ‘Light Gen’
lpu-03
Thank you! This is a file from an architect (using chief Architect). I did not build it- just applying material and slight adjustments on my end. I know… it bothers me so much. But, i’ve just decided to roll with it for this project.
Is your question really about working in Vray?
yes- I just need to render the interiors and I am not getting any of the sunlight. I am using clipping masks to get the right views but still no light
It would have been helpful if you’d indicated this was a Vray thing and put it in the right category. I’ll move it for you.
Very sorry- I was not sure that the problem was occurring in VRay. I thought it may have been settings in sketch-up. My mistake. Thank you for your help.
I f you use the cleanup3 plug-in, it could get rid of some of the unnecessary lines on your model. Have you tried with different rendering engines to check if it’s something related with Vray? I haven’t used Vray in a decade so I can’t give you an advice, but I’ll check it using enscape and twinmotion as soon as I can.
Have you tried this?
Or did you change the position of the sun?
How exactly do you want the sun to enter the interior of the house?
