Hi, i use sketchup the latest, today i saw ThomThom plugins needs to uptade. I uptade them inside extension manager. After restart sketchup there is an error..
I started the update minutes ago. as I read your post, I checked, and bam, error message.
however, upon restart, it’s fine on my end. got the sketchucation notification to update aswell (to re-link it there), but it works fine.
still broken on your side ?
I just tested… error to install from SketchUcation extension.
Error after install from downloaded kit from site - Download — SUbD
Extension Errors Report
SketchUp: 26.2.243
OS: Windows 10
Ruby: 3.2.2
Extension: SUbD (2.3.1)
Error: LoadError (126: The specified module could not be found. - C:/Users/nume/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/TT_SUbD/libraries/2.3.1.0/3.2/win64/SUbD.so)
<internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in `require'
c:/users/nume/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/tt_subd/core.rbe:67:in `<module:SUbD>'
c:/users/nume/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/tt_subd/core.rbe:8:in `<main>'
c:/users/nume/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/tt_subd/bootstrap.rbe:101:in `eval'
c:/users/nume/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/tt_subd/bootstrap.rbe:101:in `require'
c:/users/nume/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/tt_subd/bootstrap.rbe:101:in `<module:SUbD>'
c:/users/nume/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/tt_subd/bootstrap.rbe:8:in `<main>'
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:209:in `eval'
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:209:in `require'
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:209:in `load'
C:/Users/nume/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/TT_SUbD.rb:50:in `register_extension'
C:/Users/nume/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/TT_SUbD.rb:50:in `<module:SUbD>'
C:/Users/nume/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/TT_SUbD.rb:17:in `<module:Plugins>'
C:/Users/nume/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/TT_SUbD.rb:16:in `<module:TT>'
C:/Users/nume/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/TT_SUbD.rb:15:in `<top (required)>'
Error SketchUcation
Yes, still broken..
there is also a TT_Lib update. I’m on 2.16
subD works here, version 2.3.1
I knew that the update was for the three (TT, Vertex, SUbD), and first I updated TTLib, restarted SketchUp and installed SUbD after that.
could be a PC thing ? I’m on mac right now, let me boot up the other one
yeah, on my PC, did the update in the extension manager, then in sketchucation (same order as I did on mac to compare), and I keep getting the error on launch.
something is not agreeing with windows here but is fine with mac os
time to summon @thomthom . I’ll get the cookie jar.
I installed it on my PC, it immediately crashed.
Reopened SketchUp and it was fine and SubD loaded.
2.3.2 subd
2.16 TTlib
BTW, I noticed (on SketchUp 2026) when working on an example extension that the Extension Manager will copy the new extension files, but not load the new extension until I restart SketchUp. This seems to be new behavior.
