Hi,
is it possible to reinstall layout separately?
The Story:
I had trouble with a layout drawing, something (? ) completely destroyed it, so a closed LO without saving.
Restarting LO:
LO opened and immediately closed again without any further notification.
I tried a repair installation.
Same result:
SU works LO not (opens up and closes down again).
I installed the new patch: SU - 2025 0 - 660 - 288 (as administrator) - same result.
The drawing works with SU 2025 and SU 2024, it works with Layout 2024 - without problems.
But Layout 2025 is on strike.
Now in order not to start the couplet installation from the beginning:
“Is it possible to reinstall layout separately?”
Re
fjs
My system:
Betriebsystemname Microsoft Windows 10 Pro
Version 10.0.19045 Build 19045
Systemtyp x64-basierter PC
Prozessor 12th Gen Intel(R) Core(TM) i9-12900KF, 3200 MHz, 16 Kern(e), 24 logische(r) Prozessor(en)
Name NVIDIA RTX A4000
PNP-Gerätekennung PCI\VEN_10DE&DEV_24B0&SUBSYS_14AD10DE&REV_A1\4&22F77229&0&0008
Adaptertyp NVIDIA RTX A4000, NVIDIA-kompatibel
Adapterbeschreibung NVIDIA RTX A4000
Adapter-RAM (1.048.576) Bytes
Installierte Treiber
C:\windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_e5d28856b8de4960\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_e5d28856b8de4960\nvldumdx.dll,
Treiberversion 32.0.15.7283
INF-Datei oem184.inf (Abschnitt Section073)
Auflösung 3840 x 2160 x 29 Hz
04.06.2025 16:36 Application Error
Name der fehlerhaften Anwendung: LayOut.exe, Version: 25.0.0.0, Zeitstempel: 0x68363888
Name des fehlerhaften Moduls: LayOutView.dll, Version: 0.0.0.0,
Zeitstempel: 0x68363812 Ausnahmecode: 0xc0000005
Fehleroffset: 0x000000000056341a ID des fehlerhaften Prozesses: 0x984
Startzeit der fehlerhaften Anwendung: 0x01dbd56ed80af25d
Pfad der fehlerhaften Anwendung: C:\Program Files\SketchUp\SketchUp 2025\LayOut\LayOut.exe
Pfad des fehlerhaften Moduls: C:\Program Files\SketchUp\SketchUp 2025\LayOut\LayOutView.dll
Berichtskennung: e37a9717-6519-4c70-841c-69daf1e38d00
DaveR
June 7, 2025, 3:18pm
2
No. But reinstalling SketchUp and LayOut won’t hurt SketchUp if it’s installed correctly. Right click on the installer, choose Run as administrator and then select the Repair option.
Hi Dave that is exactly what a tried several times, unfortunately it didn’t work out.
Have you got any other idea?
Thanks!
fjs
Yahoo Mail: Suchen, organisieren, erobern
Are you having this issue when you try to open the Layout file that you were working on or even when you try to open a new empty file.
Hi.
when I try to open LO it crashes
and
when I try to open a skp-file , or send a SU-file fom SU to Layout, it crashes too.
Meanwhile SU opens and guess what: crashes too.
I tried it without internet connection: same result!
I found (but do not understand) this:
BugSplat.dll: 2025-06-08 12:15:46 Entered Unhandled Exception Filter
BugSplat.dll: 2025-06-08 12:15:46 Debug:
BugSplat.dll: CreateReportThreaded Starts
BugSplat.dll: CreateReportThreaded LoadLibrary
BugSplat.dll: Calling CreateMiniDump
BugSplat.dll: 2025-06-08 12:15:47 Minidump file successfully saved
BugSplat.dll: C:\Users\FJS\AppData\Local\Temp\SketchUpKNPT1TG3.dmp
BugSplat.dll: 2025-06-08 12:15:47 Debug:
BugSplat.dll: CreateMiniDump Returns
BugSplat.dll: 2025-06-08 12:15:47 Launching BsSndRpt.exe
BugSplat.dll: “BsSndRpt64.exe” /i “C:\Users\FJS\AppData\Local\Temp\BsSndRpt.ini” /dl
2025-06-08 12:15:47
*** BugSplat crash transmission report
2025-06-08 12:15:47 Minidump: C:\Users\FJS\AppData\Local\Temp\SketchUpKNPT1TG3.dmp
2025-06-08 12:15:47 AppKey: de
2025-06-08 12:15:47 MFA: x64-ucrt-ruby320!0008b3a4
2025-06-08 12:15:47 Additional file: C:\Users\FJS\AppData\Local\Temp\SketchUpLog-2025-06-08-12_14_07.log
Next:
I’ll try to install the latest graphic card driver - if there is any.
Unfortunately I’ll have to delete SU completely and reinstall it.
I already had to do it once in 2025!
I love Sketchup, but that is annoying.
Something doesn’t seem to fit together (PC-graphic card -SU???).
Thanks anyway!
Re
fjs
Did you use the migrate extensions plugin to copy the extensions from 2024 to 2025, some time ago I discovered that this plugin was causing crashes.
Do you know what graphics engine were you using before the crashes started? Maybe changing to the old engine could fix the problem but I don’t know a way to do it without actually opening layout.
Have you sent the bugsplats reports with your mail? If you have, @colin can check them and try to find a solution with the developers.
I used the migration extension some month ago, when I started SU 2025.
Unfortunately I just installed the GeForce driver (576.52) and don’t remember the old one.
But SU is running now, and I feel it runs a little faster.
But LO is still not working at all.
I think I sent the bugsplats, but I do not receive bugsplats when Layout opens up and shuts down a second later.
I’ll look at that again.
Re
fjs
Make sure to put your information on the bugsplats report and also describe what you were doing before the crash is very helpful. You can also share on the forum the crash code.
Is that of any help?
23.05.2025 - #92782-
03.06.2025 - #109337 -
04.06.2025 - #111410
04.06.2025 - #111423 ; #111430 ;
07.06.2025 - #116247 - Sketchup will nicht starten
08.06.2025 - SU läd und schaltet ab (PC ohne internetverbindung):
SketchUpKNPT1TG3.dmp C.\Users\FJS\AppData\Local\Temp
SVD55M60.xml
bugsplat.log
WGLUtils::IsExtensionFinderWindowClassRegistered: Class is already registered.
WGLUtils::EnumerateAttachedDisplayDevices: Display0 : NVIDIA RTX A4000 : PT 3
WGLUtils::UtilsState::ctor: Max GPU perf is 3
Sketchuplog-2025-06-08-12_14_07.log
WGLUtils::IsExtensionFinderWindowClassRegistered: Class is not registered.
---- Screen Config (reported by Qt) ----
Primary Screen: EV3237
position: (0, 0)
size: 2560 x 1440
scale factor: 1.500000
EV2730Q
position: (3840, 0)
size: 1536 x 1536
scale factor: 1.250000
2025-06-08:12:14:17-Query market notification
2025-06-08:12:14:17-Query market notification complete
Device Manufacturer: ASUS
Device Model: System Product Name
OS Version: 10.0
Enumerating compatible GPUs:
Adding ‘NVIDIA RTX A4000’ to compatible GPUs at index 0.
Renderer information:
Graphics Engine Name: New Graphics Engine
Graphics API: DX12
Graphics Driver Version: 32.0.15.7283
GPU Name: NVIDIA RTX A4000
Da die Mitarbeiter von SketchUp kein Deutsch sprechen, ist es besser, das Problem auf Englisch zu beschreiben.
23.05.2025 - #92782
07.06.2025 - #116247 - Sketchup won’t start
08.06.2025 - SU starts and shuts down (test without internet connection):
SVD55M60.xml
bugsplat.log
position: (0, 0)
size: 2560 x 1440
EV2730Q
position: (3840, 0)
size: 1536 x 1536
OS Version: 10.0
Graphics API: DX12
It looks quite unspectacular:
bmaxim
June 8, 2025, 3:44pm
13
I had the same issue a few weeks ago — SketchUp wouldn’t open.
The only thing that helped was to completely uninstall SU 2025 (preferably using Revo Uninstaller), and then manually check and delete the following folders:
C:\Users\Admin\AppData\Roaming\SketchUp\SketchUp 2025
After that, install the latest version of SketchUp.
By the way, I have the same graphic Nvidia RTX A4000— no more problems so far
nah, they do. they have people all around the world, and these days, they can translate stuff…
bmike
June 8, 2025, 5:37pm
15
Something to try - find the folder where the recovered files are saved for LayOut - delete the folder. Then try and restart. I had an issue where a corrupt recovered file was causing crashes as it couldn’t get past trying to load this file. Once I cleared that folder all was working.
Thank you very much I‘ll try that as soon as possible!
Re
fjs
adam
June 9, 2025, 4:15pm
17
This LayOut crash looks like it may be related to .plo files. Please check this fix out:
Reinstalling doesn’t affect the %AppData%, it might be corrupted.
Try to delete the .plo and .json files in the (hidden) %Appdata%/SketchUp/SketchUp 2022/LayOut folder
Start with only deleting .plo
Hope that helps,
Adam
Hi,
I found these files:
UserLayout_1.de.plo
DefaultLayout_1.de.plo
layout.public.json
layout.extensions.layout.pdf.public.json
LAYOUT:PUBLIC:JSON
file shows:
“Shared for All Computers”: {},
“Windows Only”: {},
“Mac Only”: {},
“Web Only”: {},
“iOS Only”: {},
“Android Only”: {},
“timestamp”: 1749395840476
LAYOUT.EXTENSIONS.LAYOUT.PDF.PUBLIC:JSON
file shows:
“Windows Only”: {},
“Mac Only”: {},
“Web Only”: {},
“iOS Only”: {},
“Android Only”: {},
“timestamp”: 1749040545196
I start deleting the *.plo-files.
If they are of interest, I’llstore them somewhere.
Reporting soon.
fjs
Thank you all very much, the problem seems to be solved!
Opening Layout → working!
Send to Layout → working!
Great support!
Re
fjs
