Hi all,
This is my first post here ![]()
I had an issue last night where my files size went from about 90MB to now 177MB.
This is a large model, and basically the only difference was that I re-created 4 and 6 seat tables, and added material, made into a component, and then placed them in a dining area. There was no new 3D work created, and nothing spectacular that I can think of that would nearly double the size of the file.
Also, SU required that I save it in 2020, and I am currently using 2023.
No problems this AM, everything seemed to open fine. However, I did check the Model info tab and got this messages on the ‘fix problems’ tab:
CLoop (3842780) for CFace (3842779) is oriented wrong - fixed
CLoop (3842786) for CFace (3842785) is oriented wrong - fixed
CLoop (3842821) for CFace (3842820) is oriented wrong - fixed
CLoop (3842830) for CFace (3842829) is oriented wrong - fixed
CLoop (3842842) for CFace (3842841) is oriented wrong - fixed
CLoop (3842849) for CFace (3842848) is oriented wrong - fixed
CLoop (3842860) for CFace (3842859) is oriented wrong - fixed
CLoop (3842887) for CFace (3842886) is oriented wrong - fixed
CLoop (3842895) for CFace (3842894) is oriented wrong - fixed
CLoop (3842903) for CFace (3842902) is oriented wrong - fixed
CLoop (3842911) for CFace (3842910) is oriented wrong - fixed
CLoop (3842918) for CFace (3842917) is oriented wrong - fixed
CLoop (3842925) for CFace (3842924) is oriented wrong - fixed
CLoop (3842934) for CFace (3842933) is oriented wrong - fixed
CLoop (3842940) for CFace (3842939) is oriented wrong - fixed
CLoop (3842948) for CFace (3842947) is oriented wrong - fixed
CLoop (3842954) for CFace (3842953) is oriented wrong - fixed
CLoop (3842980) for CFace (3842979) is oriented wrong - fixed
CLoop (3842985) for CFace (3842984) is oriented wrong - fixed
CLoop (3843006) for CFace (3843005) is oriented wrong - fixed
CLoop (3843013) for CFace (3843012) is oriented wrong - fixed
CLoop (3843022) for CFace (3843021) is oriented wrong - fixed
CLoop (3843029) for CFace (3843028) is oriented wrong - fixed
CLoop (3843053) for CFace (3843052) is oriented wrong - fixed
CLoop (3843058) for CFace (3843057) is oriented wrong - fixed
CLoop (3843072) for CFace (3843071) is oriented wrong - fixed
CLoop (3843078) for CFace (3843077) is oriented wrong - fixed
CLoop (3843105) for CFace (3843104) is oriented wrong - fixed
CLoop (3843151) for CFace (3843150) is oriented wrong - fixed
CLoop (3843161) for CFace (3843160) is oriented wrong - fixed
CLoop (3843168) for CFace (3843167) is oriented wrong - fixed
CLoop (3843176) for CFace (3843175) is oriented wrong - fixed
CLoop (3843182) for CFace (3843181) is oriented wrong - fixed
CLoop (3843198) for CFace (3843197) is oriented wrong - fixed
CLoop (3843210) for CFace (3843209) is oriented wrong - fixed
CLoop (3843216) for CFace (3843215) is oriented wrong - fixed
CLoop (3843226) for CFace (3843225) is oriented wrong - fixed
CLoop (3843273) for CFace (3843272) is oriented wrong - fixed
CLoop (3843279) for CFace (3843278) is oriented wrong - fixed
CLoop (3843285) for CFace (3843284) is oriented wrong - fixed
CLoop (3843291) for CFace (3843290) is oriented wrong - fixed
CLoop (3843388) for CFace (3843387) is oriented wrong - fixed
CLoop (3843394) for CFace (3843393) is oriented wrong - fixed
CLoop (3843415) for CFace (3843414) is oriented wrong - fixed
CLoop (3843421) for CFace (3843420) is oriented wrong - fixed
CLoop (3843444) for CFace (3843443) is oriented wrong - fixed
CLoop (3843450) for CFace (3843449) is oriented wrong - fixed
CLoop (3843476) for CFace (3843475) is oriented wrong - fixed
CLoop (3843482) for CFace (3843481) is oriented wrong - fixed
CLoop (3843498) for CFace (3843497) is oriented wrong - fixed
CLoop (3843511) for CFace (3843510) is oriented wrong - fixed
CLoop (3843521) for CFace (3843520) is oriented wrong - fixed
CLoop (3843542) for CFace (3843541) is oriented wrong - fixed
CLoop (3843552) for CFace (3843551) is oriented wrong - fixed
CLoop (3843609) for CFace (3843608) is oriented wrong - fixed
CLoop (3843615) for CFace (3843614) is oriented wrong - fixed
CLoop (3843621) for CFace (3843620) is oriented wrong - fixed
CLoop (3843626) for CFace (3843625) is oriented wrong - fixed
CLoop (3843631) for CFace (3843630) is oriented wrong - fixed
CLoop (3843636) for CFace (3843635) is oriented wrong - fixed
CLoop (3843642) for CFace (3843641) is oriented wrong - fixed
CLoop (3843648) for CFace (3843647) is oriented wrong - fixed
CLoop (3843678) for CFace (3843677) is oriented wrong - fixed
CLoop (3843687) for CFace (3843686) is oriented wrong - fixed
CLoop (3843693) for CFace (3843692) is oriented wrong - fixed
CLoop (3843720) for CFace (3843719) is oriented wrong - fixed
CLoop (3843728) for CFace (3843727) is oriented wrong - fixed
CLoop (3843774) for CFace (3843773) is oriented wrong - fixed
CLoop (3843781) for CFace (3843780) is oriented wrong - fixed
CLoop (3843788) for CFace (3843787) is oriented wrong - fixed
CLoop (3843795) for CFace (3843794) is oriented wrong - fixed
CLoop (3843805) for CFace (3843804) is oriented wrong - fixed
CLoop (3843811) for CFace (3843810) is oriented wrong - fixed
CLoop (3843846) for CFace (3843845) is oriented wrong - fixed
CLoop (3843854) for CFace (3843853) is oriented wrong - fixed
CLoop (3843863) for CFace (3843862) is oriented wrong - fixed
CLoop (3843871) for CFace (3843870) is oriented wrong - fixed
CLoop (3843876) for CFace (3843875) is oriented wrong - fixed
CLoop (3843898) for CFace (3843897) is oriented wrong - fixed
CLoop (3843904) for CFace (3843903) is oriented wrong - fixed
CLoop (3843912) for CFace (3843911) is oriented wrong - fixed
CLoop (3843920) for CFace (3843919) is oriented wrong - fixed
CLoop (3843926) for CFace (3843925) is oriented wrong - fixed
CLoop (3843960) for CFace (3843959) is oriented wrong - fixed
CLoop (3843965) for CFace (3843964) is oriented wrong - fixed
CLoop (3844076) for CFace (3844075) is oriented wrong - fixed
CLoop (3844082) for CFace (3844081) is oriented wrong - fixed
CLoop (3844117) for CFace (3844116) is oriented wrong - fixed
CLoop (3844124) for CFace (3844123) is oriented wrong - fixed
CLoop (3844177) for CFace (3844176) is oriented wrong - fixed
CLoop (3844182) for CFace (3844181) is oriented wrong - fixed
CLoop (3844188) for CFace (3844187) is oriented wrong - fixed
CLoop (3844194) for CFace (3844193) is oriented wrong - fixed
CLoop (3844200) for CFace (3844199) is oriented wrong - fixed
CLoop (3844211) for CFace (3844210) is oriented wrong - fixed
any ideas?
FYI, Recent M-Arch grad, but this is my first full model in SU, so I am familiar with it, but don’t know the ins and outs yet. thinking of basecamp this year.
Dan
