I am having an issue with SU2017 rectangle tool, it is filling not only the rectangle but also areas outside the rectangle.
if you are crossing ‘loose’ geometry it will try to find all the faces…
add an image or your skp file for further advice…
john
Fazio Plan SU2.skp (5.8 KB)
Thanks John, Even though I have not been using SU long, it’s the first time this has happened.
I’m not sure if an empty file can help us to help you.
The fazio plan SU2 is 5.8KB
Yes, but there’s no geometry in it?
Did you turn the layers on
? Those are not the layers from my file.
Scary, my filename but not my drawing.
From your screenshot…
Fazio2.skp (498.5 KB)
I thought the plan was grouped but it was not, so I grouped it and it seems to be working fine now. Thanks for your help. On a side note is it possible to keep all lines on layer 0, and groups on different layers? Thanks Again!
It is not only possible, it is the recommended way to use layers!
