Hello, I am trying to render a scene with Vray but I continue to have these strange refelctions/objects appearing while rendering that I don’t have in the scene. How do I get rid of these?
Many thanks
Check the faces orientation and the groups.
Saul
May 30, 2023, 3:45pm
3
They look like the backs of objects like bookcases and desks and stuff as seen through an exterior wall. Do you have any hidden objects in the scene?
Yes I do have some hidden objects, but even if I ‘‘unhide all’’ the problem remains
Saul
May 30, 2023, 4:12pm
5
I don’t think V-Ray cares about SU settings like that. It’ll render whatever’s there even if you hide it in SU. (Maybe I’m wrong, though. I use V-Ray 6 a lot but never have anything hidden.)
But if that would be the problem then I wouldn’t see the strange white thing when I unhide everything… right?
Do you know what the correct orientation of faces means? White on the outside, blue on the inside. Have you checked the model, setting Monochrome Style?
I am not very familiar with the face orientation, how do I know which one is blue or white if I have a texture on the face?
You can find many other cases like this if you search the forum:
Hello,
I have a sketchup model (2020 version) and am trying to create a sectional perspective using Vray. When I cut a section, on sketchUp it looks fine but my renders are not coming out right. I’ve attached pictures.
[Screenshot 2021-05-12 at 00.39.45]
Please could someone advise me on what to do. I have the latest version of Vray.
I have been trying to render a scene on Vray 5.2 on sketchup 2019. The section plane/clipper in the geometry section is not working properly. I have unticked the ‘Affect light’ box and yet The render lets the environment lights in the render. I have tried tweaking my camera angles and field of view in different ways. But nothing seems to work for me. attached it the image of the render. Can someone please help with this?
[Screenshot_2]
I have a problem with section plane. I position it and it seems fine (in the middle of the room) but during rendering it shows like I would be in the middle of the wall or cabinet behind camera and it shows inside of the cabinet and lines for tiles. What do I do wrong?
