"Some imported geometry is extremely far from the model origin" error while trying to import .dwg file
Got it now! Thank you so much for trying!
Convert to what though? Could you please elaborate?
You’re welcome, @SeanB ! You’re welcome, @Lakshmi !
If you have Autocad, try to 2d polyline and see if it is ok to import, or if you have an ACAD alternative, explode them and they will become lines and you will be able to import the dwg file.
Also, Purge the file.
HI
I have the same problem when i import dwg file to su and i dont no how to fix it can you help me
لاند للرفع.dwg (603.5 KB)
dwg-import-2.skp (494.2 KB)
thank you alot
You’re welcome! Download again this file -
Try coping only the elements you need on a new autocad file and then import the new file.
