Solar Path Plug-In or Setting?
Hello!
I am working on a model and I would like to have a visible solar path, similar to the old Eco-tect program. Is this already in the program somewhere? If not, is it available in an extension? It would really help explain the sun to students and clients.
Thank you for your help,
Kris
Hi Kris,
This might be what you’re looking for.
It’s old, but I tried it in SU 2016 for Windows and it worked.
Sun_course SketchUp Plugin by G. Miller — Ruby Library Depot
Here’s how it looks…
Thank you so much! This is what I was hoping for!
Kris
Hello,
One more question - how did you get this to load? I’ve tried unzipping it to the plugin folder, and I’m not having a ton of luck. Any suggestions are appreciated!
Thank you,
Kris
Hello Kris, @kmnelson
The download from Ruby Library Depot is a compressed .zip folder named sunposition.zip
Simply change the file extension to sunposition.rbz and then install it via the Preferences - Extension panel
Look to the top menus in SU
Window > Preferences > Extensions > Install Extension
Upon installation the plugin appears under the Draw menu as Sun Position V1.2
Update
@kmnelson
Notice in the plugin’s flyout menu that the link to ‘How to Use Sun Position’ is broken.
Here is the link to the current User Guide for the plugin.
SketchUp Sun Position Plugin User Guide at Cerebral Meltdown.com
Welcome cerebralmeltdown.com - BlueHost.com
Also note there’s an updated version available … Sun Position V1.2.1
