I softened edges on a simple object in sketch up and when viewed in layout doesn’t show the edge definition I want. How do I unsoften edges…is there such a thing?
Open up the Soften Edges Tool Menu…
… >Windows >Soften Edges.
Slider Control works in both directions.
You can also unhide the edge:
With view hidden geometry turned on… select the hidden edges and use the unhide command,
In SketchUp use [Ctrl] plus [Shift] plus the ’ Eraser’ tool to get the edges back to normal. Do so with ‘Hidden Geometry’ visible. Or use ‘Entity Info’ to uncheck ‘Soften’ per (selection of) edge(s).
