Slowness in selection tool on SketchUp
I was using SketchUp when it started to slow to select models, groups and faces, I thought it was because the file was large, but I opened a new file and tried to select the template that already comes in it, I waited many seconds until it was selected, And the same happens when I have to deselect it, I concluded that the problem was not in the file.
I uninstalled SketchUp and re-installed but the problem continued, I do not know what to do, because I can not use the program like that.
Someone help me
If you search this forum for ‘slow selection tool’ you will find explanations for common causes, and fixes. One recent common cause is a Windows update, which can be uninstalled.
