Sketchup's "Create Layout file From scene" feature
Sorry if this has already been covered… if it has, a link would be appreciated.
When I use the Sketchup “Create Layout file From scene” feature the viewports created are off centre in layout.
This is no issue when the style background is white, however, with colured background, the viewport extends over the right margin (landscape view).
While the viewpost can be resized/moved, it becomes cumbersome for 100+ scenes.
Is there a global method to centre viewports. I am running SU 2018… is this feature “fixed” in later versions?
Are you referring to the extension called " Create LayOut File"? If so. There’s been no change in it since it was released in 2015.
You can right click on a viewport and choose Center>Horizontally on Page. Maybe easier to create a shortcut.
I’ve never found it useful or worthwhile putting a single viewport on each page in a woodworking plan but I’m sure that’s just me.
Thanks for the reply Dave. Yes, I was referring to the extension.
Short reply… thanks for that “Right click → centre → Horizontally”… greatly appreciated… exactly what I wanted.
Long reply… I often import copyrighted plans into SketchUp (usually detailed model toys)… I believe it’s an infringement to release the model to non plan paying people.
By exporting it into layout and consequently into a PDF, I don’t believe they have sufficient detail to plagiarise the plan, yet can get a fair perspective of what I’m trying to convey… measurements are deliberately omitted in the PDF.
Again, thanks and keep safe (all)…
Alex
Generally if I have to share images of a Sketchup model in LO I turn off the layers for dimensions and text and then provide a screen shot similar to this.
Thanks Dave.
That is neat but way above my pay grade. I’m just a hacker that hates to read… probably why I hadn’t picked up on your tip.
For my purposes, the less time I spend in Layout the better. My primary use of Layout is a 1:1 transition from SketchUp to CorelDraw… usually for laser work… and PDF creation.
It only creates one scene and not all of them.
How is your model constructed? Can you share it so we can see what you are working with? Are you still using SketchUp 2019 as indicated in your profile?
How is your model constructed? Can you share it so we can see what you are working with? Please see attached.
Are you still using SketchUp 2019 as indicated in your profile? Yes.
396 3 013.skp (143.6 KB)
I just ran that extension on your model and I’ve got 8 pages as expected. What does the Pages panel look like in your LO file?
Yes, it worked, but …
When one exports using Create Layout file From scenes - only the first scene was a vector, all the others were bmp.
When one exports each scene separately from SU one gets a pdf/vector file.
You would need to have rendered all the view ports as vector before export. Same as if you make and place the view ports manually.
I did, but it only rendered the first one as a vector. All the other ones were PDF with a bmp background.
Did you go through all of the viewports and render them as Vector? That’s not going to happen automatically. You will have to step through every page, select the viewport, and choose Vector render for it.
Share your LO file so we can see what you’ve got…
I don’t see a render option but in the tray, there is SketchUp Model/View/Vector.
396.layout (495.8 KB)
OK. So this is clearly a training issue, not an issue with the extension or LayOut.
By default when the viewports are initially created they are rendered as Raster. You need to select the viewport and change the render type to Vector. This is a per viewport thing so you have to do it for every viewport that you want rendered that way. SketchUp Modelpanel looks different in the ancient version you are using but the idea is the same.
render
FWIW, if you create the viewports yourself instead of relying on the extension, you can render the first one as Vector and then copy it to the additional pages as needed. Then you only need to select the appropriate scene. Or as I showed earlier in this thread, you could have multiple viewports on a single sheet.
