Sketchup this does not appear to be a sketchup model! error! help! urgent!
hello, my file project is broken, please help someone open my file. and fix him. thank you verymuch.
Layout Design Tirtir Pop Up Store ALT 2.skp (9.5 MB)
The file you posted contains nothing, but zeros. Unfortunately it cant be recovered. You can check - if you have .skb file (rename it to .skp) if that is opens or not.
Are you using cracked version of Sketchup?
Even the SKB file can’t be opened either.
I don’t know whether to use the cracked version of Sketchup or not, because this file belongs to my friend
If your friend is using cracked software, there is a good chance of damaging the file.
If you are using cracked software, there will be more problems…
Correct as usual dezmo. Cracked versions of software are illegal to use and sometimes the cracking process can trigger unintended behaviors to emerge. With SketchUp, that behavior usually damages the file in a way that is similar to the file you posted.
If you are not using a cracked version of SketchUp, you should always be backing up your work to the cloud service that we have built in to SketchUp, Trimble Connect.
Additionally, you should always make sure you save the initial file to an internal drive on your computer and not to external drives or USB drives. Saving directly to one of those can cause problems sometimes. Copying the file to one of those after saving the file to an internal drive is fine as that seems to avoid the issue.
As for why the issue happens with external drives and USB drives, we don’t have a way to reliably trigger it so tracking down the cause of that bug is problematic for us. If you figure out a way to reliably trigger it, let us know the details so we can add that info to our testing process.
