Hey Guys! I need help. Everytime I applied a material texture on the object, it doesn’t show the materials but only the color and lines are shown.
well share your file so we can look.
from your screenshot, it looks like you tried to change the colour of the material. something more orange-y.
but you didn’t change the luminosity, it’s all the way down to almost black. if you want orange, you need to slide up the cursor next to the colour wheel.
I didn’t change the color. I left it as is. It’s supposed to look like a walnut semi gloss from the Chaos Cosmos
https://drive.google.com/file/d/1Ae_tzFnSlHdvQJ4YfjK1q5RZMgB4nFJ4/view?usp=drive_link
ah, you’re using Vray’s assets. have you tried rendering ? that’s what they’re made for
also, your drive link needs to be in public mode, right now it’s restricted.
There is no problem in rendering. But I want to see the material texture before rendering to see if it’s good for the design or not.
I am unable to send the link. It says “cannot post a link to that host”
Did you turn on ‘binding’ in the VRay asset editor?
Some procedural materials will show as a weird pattern.
Not sure because this problem never happened before and I’ve been using Sketchup and Vray for almost 10 years now. Where in the VRay asset editor is the ‘binding’ located?
Go to the material that isn’t working and look in the edit panel for the materials options / attributes.
Is it an older model recently re-opened in VRay 7? I find I had to update some of them from old projects.
I managed to solve the problem by going to the VRay Asset Editor>(the material that isn’t working)>Viewport Display>Texture>Choose Custom and click the bitmap and go to (User/(name)/Documents/Chaos Cosmos/Packages) then you have to find the material that isn’t working
