Hi
I imagine that there is a quick answer to this but it’s baffled me.
For some reason Sketchup Version 19 will not import a DWG file that Version 18 has no problem with.
Does anyone have any ideas on this one?
Kind regards
Mike
Hi
Kind regards
Mike
Can you share the DWG?
No worries.
Banbury CC Survey.dwg (22.8 KB)
Version 18 imports it no problem.
Mike
EDIT: Even tried saving it as a AutoCAD V2000 Version.
That’s exactly what it should look like.
I just get an import Failed on Version 19. On Version 18, I get the same as you got.
Mike
Weird. I wonder why the difference between PC and Mac.
Being really cynical, it will be ANOTHER thing that Macs have trouble with and will never get fixed.
So, I exploded the drawing in AutoCAD first, then saved it, and it imported ok.
Mike
What’s a picnic bug?
Tried with the same settings. No luck
I’ve made sure the DWG is moved to 0,0,0 in CAD Software.
Banbury CC - Survey.dwg (25.2 KB)
EDIT: The report you show @john_drivenupthewall is the same as I get in Sketchup Version 18. The one I have just uploaded is the one I get from Version 19.
nerdy humour…
problem in chair not in computer…
edit: my report is from v19…
john
Tried everything;
AutoCAD Release 2013 Version, 2018 Version, Release 14 Version, DXF Version.
Absolutely will not import.
Here’s a thought. I am using BricsCAD.
Would you be able to save it in a DWG using your CAD software and send back to me so I can try that, to see if it is BricsCAD being a S**t!
Mike
Here’s two more which imported perfectly in Sketchup Version 18. 19 is having none of it.
Kind regards
Mike
kings school worc.dxf (31.5 KB) kings school worc.dxf (31.5 KB)
Banbury CC Survey.dxf (117.8 KB)
How about a DXF file? Any difference?
Thankyou. Long answer is No.
Did not work.
Mike
I am using Sketchup Version 19 on my MacBook Pro under High Sierra.
Weird.
My windows 7 system: no luck (Banbury survey)
Doesn’t work in iMac running Mojave either, so it’s not that.
