Hey there,
My sketch Pro 2022 keeps crashing when I try to open scenes. Is there a fix for this? Also, when I try to install Advanced Camera tools, I get a message saying not supported with Sketchup 2022 and or my latest Mac update. Any info to help solve these issues would be greatly appreciated.
I am not sure about the crashing when going to scenes, if you see a bugsplat, could you send one in?
Advanced Camera Tools was dropped from being included with SketchUp. I don’t know what the reasons were. In the extension warehouse page it only says compatibility with 2021. There is a good chance it wasn’t updated for Apple Silicon. If you are on an M1 Mac, try Get Info on SketchUp, and check the box to open with Rosetta. See if that makes the extension work, and also if the crashes stop.
If you want to get better performance when not using that extension, you could duplicate the SketchUp application inside Applications/SketchUp 2022, and set only one of the two copies to open with Rosetta. Then you can use the other copy to get better performance.
This is is the message I get when trying to download
Sketchup 2022 seems to be compatible with Ventura as I was working fine before using Advanced Camera Tools. I was wondering if there is an alternative extension I could use with similar capabilities as Advanced Camera Tools instead of having to use Sketchup 2021?
Thanks. Took me a moment to find it because you used a different email than the one you use in the forum! Thanks for mentioning scenes in the description.
