SketchUp Pro 2018 MacOS,
Selection window (lasso?) indicator not visible. Will select objects, can’t see what precisely
The rendering issues of the selection rectangle are a common graphics glitch that indicates an issue with the graphic driver. This not only occurs on bad graphic chips, but can also happen when a driver is updated (with a fresh OS version).
Take a look if the macOS version of SketchUp offers in the menu SketchUp → Preferences → OpenGL the option “Use fast feedback”, and check that it is enabled.
Thank you for quick reply! Checked “Fast Response”, but no change. Selection window indicator still not visible. MacBook kinda old (circa 2009), might be graphics card, altho SketchUp Pro 2017 works just fine. Thanks again
