When using the selection tool to select multiple items selection box lines are not visible.
Sketchup 2015
That sounds like it could be your graphic card. You can verify this by temporarily disable hardware acceleration under Preferences > OpenGL.
If that makes the lines become visible it’s a graphic card issue for sure and you should try to update your drivers. You might want to check if your graphic card meets the requirement of SketchUp.
That did it.
Thanks a bunch
MacOS 10.13.6 with NVIDIA GeForce GT 330M 512 MB
Intel HD Graphics 288 MB, Selection Box Not visible. What should I do to make it visible?
Problem solved.
OpenGL
go to Multisample anti=aliasing
Select and make sure the setting is “0x”
Hope this help…
You mention two graphic cards in your post, make sure the Nvidia one is being used by Sketchup.
