SketchUp Pro 2016 computer change
Hello everyone,
We recently switched computers, and SketchUp Pro 2016 isn’t working on the new one because it couldn’t find an activated license.
Do we need to delete the license from the old computer and then add a new license on the new one using “add license”?
We tried adding the license without deleting it first, but nothing happens on the screen where you add the license. The same thing happens when we try to add the wrong license. There’s no error message or any other notification.
Thank you very much.
There is an option to “remove license” which is meant to tell the ancient old classic license servers that you aren’t using it anymore.
That then frees it up to then activate it on another machine
I have the feeling that the license servers are no longer active. When I try to remove the license on the new PC where the hard drive was cloned, it says “Page not found.” When I try to install a license and click “install,” nothing happens, neither if I enter incorrect information nor the correct license.
I have the same problem today! Did you have any progress? Or do you still cant use the classic license servers?
On another topic, Colin from the Sketchup team informed that the classic license server had a problem. It’s now fixed and working normally to deactivate ou activate the classic licenses.
