Every few starts of SketchUp Pro 2015 I get a ‘bugsplat’ right after startup and it shuts down. I restart about 10 times and it will finally run. OS is Windows 7. Does anyone familiar with this problem / have a solution?
Thanks, Gregg
Thanks, Gregg
Typically when SketchUp quits during startup, the problem can be traced to the graphics card or its drivers. Since your profile is blank, I don’t know what you have but you should check for updates.
Okay, thanks, I will try that.
The second most common cause of bugsplats on startup is misbehaving extensions/plugins, though it is less likely that they would crash most of the time but not always.
