Hi All,
I was wondering if something similar to the below would be possible within sketchup, not so much the stand itself but the lighting, background colour and the flooring…
Maybe a template or extension?
Thanks in advance for any help.
Hi All,
The model is absolutely doable in SketchUp.
The lighting/reflections would have to be done in a rendering software (which can be fed from SketchUp).
There are quite a few threads on this forum about renderers. Take a look at a few and you will see that this should be pretty easy to do!
I was thinking of using a free rendering program first, so i have installed Brighter3d and Kerkythea. However I’m finding it difficult to work my way around them both, the websites are less than useful as well!
here is my SketchUp model ( Dropbox - Error ) would someone be kind enough to help me on making it look similar to the first image i attached? for example adding actual light onto my lights, a background and the reflective flooring.
Thanks in advance!
Hi Leon,
do you still need to render that?
Your link is broken.
If you send me the model I can make render and tutorial video, how to do that step by step…
Best Regards,
brighter3d
Here is my SKP file, I’ve been looking into adding a exhibition hall into the background but i cant figure out how, or find an image to suit! Any help would be much appreciated.
Would you mind showing me a step by step for the different shots please? also is there anyway you can resize the HDR’s to look more in proportion?
Is there someone i can contact to possible make a HDR look exactly how i want?
I will make video tutorial, should be ready for tomorrow…
HDR maps are made in real scale (depending on photographs), in brighter3d you can rescale them a bit but not too much…
You can ask photographers, but it is very tricky to create good hdr map.
You can find the links for free HDR textures here:
http://www.brighter3d.com/forums/topic/faq-and-known-issues/
My model is to real scale but doesn’t look in proportion to those HDR’s?
Thanks for your help, look forward to seeing that video.
Yeah, I mean each HDR map has got its own scale, it can be changed a bit but in small range…
