SketchUp not pulling in all points from Rhino
I have to bring it into SU to save it as a file that the CNC will be able to read. Weird, I know, but its the only way I can convert it.
Ok, I see what you’re getting at now, usually I go the other way. Have you been successful at this before using the points thing or is it the first time you have tried this?
I understand you are using those points as bore hole co-ordinates. Whenever I do this I draw circles to represent the holes, in the machines any circle less than a 12mm dia. will be recognised as a ā€œboreā€ operation. Any above the 12 mark will be assigned a toolpath that is routed, that’s something that’s setup in the parameters. I don’t know if you could do that with yours.
What format do you convert to?
I have done this many times. This file seems to have the snap locations a bit smaller than previous ones and I am converting to a .UC file.
