Sketchup Makes SSD Run at 100 %
I have 12 icons. 8 recent and 4 recovered. Not sure how I did that. I just use the program.
Thanks, that gives me an idea. I can put lots of big files into the auto save folder, and they then would show up as recovered, making the list a lot longer.
@colin In response to the Comp Sci. question “In the Desktop App logs, we could see a magnitude of actions that the originator process is reported as sketchup_metadata_extractor.exe and sketchup.exe.”
they suggested “performing the read file operation with a larger chunk of data: use a bigger buffer to read the data to perform fewer ReadFile calls.”
just passing along the info as this is way over my head. I just use the programs…
Thanks, I will try to find the same logs on my PC.
We have a solution yet?
I tried repairing my skp install still does the same thing. @colin Any solution to this?
hello, have you tried in the 2025 version that was just released ?
I usually wait for the next update and the major bugs are fixed and/or once everything I use has the correct plugins working. Plus the signing out and signing in step when going back and forth from skp24-25 is a miserable experience.
