Hello,
I get SketchUp Make (x64) license error: “Sketch up can not start due to a license error.”
At first it worked perfectly, but now it shows this error.
I don’t even get to the opening screen.
I tried to reinstall it.
I found it similar to this topic: http://forums.sketchup.com/t/sketch-make-licence-error/4050
I’m using Windows 7 Professional SP1.
algiuxas:
Install via right-click and choose “Run as administrator”
Right-click the SketchUp icon, choose “Properties”, switch to the “Compatibility” tab, and check the box at the bottom in the “Privilege Level” group to “Run this program as an administrator”.
Also be sure your firewall or security application is not sandboxing SketchUp.
Thanks, but It didn’t solved the problem…
Are you running Windows in a virtual machine under Linux ?
No, I’m not running Windows in a virtual machine.
I’m trying to run SketchUp under Windows 7 Professional SP1.
Okay, just making sure. You had Linux listed as one of your OSes.
Have you checked your event logs for any clues ?
Control Panel > Administrative Tools > Event Viewer
I found these reports:
NonCritical_SketchUp.exe_7f7398b4a7db5126c866d280455960fbe263_13cf4683/Report.WER
Version=1
EventType=PCA2
EventTime=131077895756915000
Consent=1
ReportIdentifier=13dcd868-1a9a-11e6-b054-d8515d36403e
Response.type=4
Sig[0].Name=Problem Signature 01
Sig[0].Value=SketchUp.exe
Sig[1].Name=Problem Signature 02
Sig[1].Value=16.1.1449.0
Sig[2].Name=Problem Signature 03
Sig[2].Value=SketchUp Application
Sig[3].Name=Problem Signature 04
Sig[3].Value=SketchUp Application
Sig[4].Name=Problem Signature 05
Sig[4].Value=Trimble Navigation Limited
Sig[5].Name=Problem Signature 06
Sig[5].Value=200
Sig[6].Name=Problem Signature 07
Sig[6].Value=-1
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
FriendlyEventName=Program Compatibility
ConsentKey=PCA2
AppName=SketchUp Application
AppPath=C:\Program Files\SketchUp\SketchUp 2016\SketchUp.exe
NonCritical_SketchUp.exe_7f7398b4a7db5126c866d280455960fbe263_cab_0ffaed79/Report.WER (I think this is report when SketchUp was working)
Version=1
EventType=PCA2
EventTime=131077094458055000
Consent=1
ReportIdentifier=82c7d6f8-19df-11e6-930f-fa5d8e23ad0f
Response.type=4
Sig[5].Value=200
Sig[6].Value=-1
File[0].CabName=appcompat.txt
File[0].Path=appcompat.txt
File[0].Flags=65536
File[0].Type=5
File[0].Original.Path=C:\Users\Algirdas\AppData\Local\Temp\{cf401c42-b616-49e7-a8bb-018f7f33cad5}\appcompat.txt
File[1].CabName=TabEB09.tmp
File[1].Path=TabEB09.tmp
File[1].Flags=65536
File[1].Type=5
File[1].Original.Path=C:\Users\Algirdas\AppData\Local\Temp\TabEB09.tmp
ConsentKey=PCA2
appcompat.txt
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="SketchUp.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="alchemyext.dll" SIZE="248320" CHECKSUM="0xBABBBAE4" BIN_FILE_VERSION="16.1.1449.0" BIN_PRODUCT_VERSION="16.1.1449.0" PRODUCT_VERSION="16.1.1449" FILE_DESCRIPTION="alchemyext" COMPANY_NAME="Trimble Navigation Limited" PRODUCT_NAME="SketchUp" FILE_VERSION="16.1.1449" ORIGINAL_FILENAME="alchemyext.dll" INTERNAL_NAME="alchemyext" LEGAL_COPYRIGHT="(c) 2016 Trimble Navigation Limited" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x464B6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="16.1.1449.0" UPTO_BIN_PRODUCT_VERSION="16.1.1449.0" LINK_DATE="02/24/2016 19:31:56" UPTO_LINK_DATE="02/24/2016 19:31:56" EXPORT_NAME="alchemyext.dll" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="avcodec-55.dll" SIZE="9876992" CHECKSUM="0x18C37BC2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x96CEAD" LINKER_VERSION="0x0" LINK_DATE="03/19/2014 16:52:02" UPTO_LINK_DATE="03/19/2014 16:52:02" EXPORT_NAME="avcodec-55.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="avformat-55.dll" SIZE="1403904" CHECKSUM="0x807BFFFC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x15D497" LINKER_VERSION="0x0" LINK_DATE="03/19/2014 16:52:02" UPTO_LINK_DATE="03/19/2014 16:52:02" EXPORT_NAME="avformat-55.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="avutil-52.dll" SIZE="266752" CHECKSUM="0x96FE1E78" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4E8A4" LINKER_VERSION="0x0" LINK_DATE="03/19/2014 16:52:04" UPTO_LINK_DATE="03/19/2014 16:52:04" EXPORT_NAME="avutil-52.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="BsSndRpt64.exe" SIZE="384464" CHECKSUM="0x9293FFE4" BIN_FILE_VERSION="3.3.0.8" BIN_PRODUCT_VERSION="3.3.0.8" PRODUCT_VERSION="3, 3, 0, 8" FILE_DESCRIPTION="Crash reporting Send Utility, BsSndRpt.exe" COMPANY_NAME="BugSplat, LLC" PRODUCT_NAME="BugSplat Crash Report Send Utility" FILE_VERSION="3, 3, 0, 8" ORIGINAL_FILENAME="BsSndRpt.exe" INTERNAL_NAME="BsSndRpt.exe" LEGAL_COPYRIGHT="Copyright BugSplat, LLC (C) 2013" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5EC84" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.3.0.8" UPTO_BIN_PRODUCT_VERSION="3.3.0.8" LINK_DATE="01/18/2014 17:52:09" UPTO_LINK_DATE="01/18/2014 17:52:09" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="BugSplat64.dll" SIZE="283088" CHECKSUM="0xE1AA9319" BIN_FILE_VERSION="3.3.0.8" BIN_PRODUCT_VERSION="3.3.0.8" PRODUCT_VERSION="3, 3, 0, 8" FILE_DESCRIPTION="Crash reporting module, BugSplat.DLL" COMPANY_NAME="BugSplat, LLC" PRODUCT_NAME="BugSplat Dynamic Link Library" FILE_VERSION="3, 3, 0, 8" ORIGINAL_FILENAME="BugSplat.DLL" INTERNAL_NAME="BugSplat.DLL" LEGAL_COPYRIGHT="Copyright BugSplat, LLC (C) 2013" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x51A3A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.3.0.8" UPTO_BIN_PRODUCT_VERSION="3.3.0.8" LINK_DATE="01/18/2014 17:42:02" UPTO_LINK_DATE="01/18/2014 17:42:02" EXPORT_NAME="BugSplat64.dll" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="BugSplatRc64.dll" SIZE="188416" CHECKSUM="0x6FE06C8D" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1, 0, 0, 1" FILE_DESCRIPTION="Crash reporting module, BugSplatRc" COMPANY_NAME="BugSplat, LLC" PRODUCT_NAME="BugSplatRc Dynamic Link Library" FILE_VERSION="1, 0, 0, 1" ORIGINAL_FILENAME="BugSplatRc.DLL" INTERNAL_NAME="BugSplatRc" LEGAL_COPYRIGHT="Copyright BugSplat, LLC (C) 2003" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3A1A7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="03/13/2014 17:40:06" UPTO_LINK_DATE="03/13/2014 17:40:06" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="collada.dll" SIZE="4760576" CHECKSUM="0x6F910F4" BIN_FILE_VERSION="16.1.1449.0" BIN_PRODUCT_VERSION="16.1.1449.0" PRODUCT_VERSION="16.1.1449" FILE_DESCRIPTION="SketchUp COLLADA Plugin" COMPANY_NAME="Trimble Navigation Limited" PRODUCT_NAME="SketchUp COLLADA Plugin" FILE_VERSION="16.1.1449" ORIGINAL_FILENAME="collada.dll" INTERNAL_NAME="collada.dll" LEGAL_COPYRIGHT="(c) 2016 Trimble Navigation Limited" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x48C12B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="16.1.1449.0" UPTO_BIN_PRODUCT_VERSION="16.1.1449.0" LINK_DATE="02/24/2016 19:33:57" UPTO_LINK_DATE="02/24/2016 19:33:57" EXPORT_NAME="collada.dll" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="common_application.dll" SIZE="38912" CHECKSUM="0x67D430F0" BIN_FILE_VERSION="16.1.1449.0" BIN_PRODUCT_VERSION="16.1.1449.0" PRODUCT_VERSION="16.1.1449" FILE_DESCRIPTION="common_application" COMPANY_NAME="Trimble Navigation Limited" PRODUCT_NAME="SketchUp" FILE_VERSION="16.1.1449" ORIGINAL_FILENAME="common_application.dll" INTERNAL_NAME="common_application" LEGAL_COPYRIGHT="(c) 2016 Trimble Navigation Limited" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x16980" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="16.1.1449.0" UPTO_BIN_PRODUCT_VERSION="16.1.1449.0" LINK_DATE="02/24/2016 19:31:50" UPTO_LINK_DATE="02/24/2016 19:31:50" EXPORT_NAME="common_application.dll" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="dbghelp.dll" SIZE="1413072" CHECKSUM="0xF41DAAC7" BIN_FILE_VERSION="6.2.9200.20512" BIN_PRODUCT_VERSION="6.2.9200.20512" PRODUCT_VERSION="6.2.9200.20512" FILE_DESCRIPTION="Windows Image Helper" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="6.2.9200.20512 (debuggers(dbg).120906-1803)" ORIGINAL_FILENAME="DBGHELP.DLL" INTERNAL_NAME="DBGHELP.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x162DF4" LINKER_VERSION="0x60002" UPTO_BIN_FILE_VERSION="6.2.9200.20512" UPTO_BIN_PRODUCT_VERSION="6.2.9200.20512" LINK_DATE="09/07/2012 05:45:49" UPTO_LINK_DATE="09/07/2012 05:45:49" EXPORT_NAME="dbghelp.dll" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="gdal16.dll" SIZE="3322368" CHECKSUM="0x845D1080" BIN_FILE_VERSION="1.6.2.0" BIN_PRODUCT_VERSION="1.6.2.0" PRODUCT_VERSION="1.6.2" FILE_DESCRIPTION="Geospatial Data Abstraction Library" COMPANY_NAME="OSGeo" PRODUCT_NAME="GDAL/OGR" FILE_VERSION="1.6.2" INTERNAL_NAME="GDAL" LEGAL_COPYRIGHT="See LICENSE.TXT" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.6.2.0" UPTO_BIN_PRODUCT_VERSION="1.6.2.0" LINK_DATE="03/06/2014 22:28:33" UPTO_LINK_DATE="03/06/2014 22:28:33" EXPORT_NAME="gdal16.dll" VER_LANGUAGE="Language Neutral [0x0]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="IGAttrs.dll" SIZE="1171456" CHECKSUM="0xA6041F4F" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12DFDA" LINKER_VERSION="0x0" LINK_DATE="03/07/2014 18:00:14" UPTO_LINK_DATE="03/07/2014 18:00:14" EXPORT_NAME="IGAttrs.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="IGCore.dll" SIZE="2036736" CHECKSUM="0x72DBC2FE" MODULE_TYPE="WIN32" PE_CHECKSUM="0x200CE2" LINKER_VERSION="0x0" LINK_DATE="04/03/2014 19:05:46" UPTO_LINK_DATE="04/03/2014 19:05:46" EXPORT_NAME="IGCore.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="IGGfx.dll" SIZE="4776448" CHECKSUM="0x5F74961" MODULE_TYPE="WIN32" PE_CHECKSUM="0x490DB6" LINKER_VERSION="0x0" LINK_DATE="03/07/2014 18:00:13" UPTO_LINK_DATE="03/07/2014 18:00:13" EXPORT_NAME="IGGfx.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="IGMath.dll" SIZE="986112" CHECKSUM="0x4A16DE5" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF774D" LINKER_VERSION="0x0" LINK_DATE="03/07/2014 18:00:12" UPTO_LINK_DATE="03/07/2014 18:00:12" EXPORT_NAME="IGMath.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="IGSg.dll" SIZE="2107904" CHECKSUM="0xE9CB8470" MODULE_TYPE="WIN32" PE_CHECKSUM="0x212534" LINKER_VERSION="0x0" LINK_DATE="03/07/2014 18:00:15" UPTO_LINK_DATE="03/07/2014 18:00:15" EXPORT_NAME="IGSg.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="IGUtils.dll" SIZE="437760" CHECKSUM="0x2D90A1B2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x75410" LINKER_VERSION="0x0" LINK_DATE="03/07/2014 18:00:12" UPTO_LINK_DATE="03/07/2014 18:00:12" EXPORT_NAME="IGUtils.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="ImportCommon-3.25.dll" SIZE="94720" CHECKSUM="0x261D7D73" BIN_FILE_VERSION="3.25.0.0" BIN_PRODUCT_VERSION="3.25.0.0" PRODUCT_VERSION="3.25 (24.9.2014)" FILE_DESCRIPTION="Import Common dll" COMPANY_NAME="Tekla Corporation" PRODUCT_NAME="ImportCommon" FILE_VERSION="3.25" ORIGINAL_FILENAME="ImportCommon.dll" INTERNAL_NAME="ImportCommon" LEGAL_COPYRIGHT="Copyright © Tekla Corporation 2014" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.25.0.0" UPTO_BIN_PRODUCT_VERSION="3.25.0.0" LINK_DATE="09/24/2014 10:41:32" UPTO_LINK_DATE="09/24/2014 10:41:32" EXPORT_NAME="ImportCommon-3.25.dll" VER_LANGUAGE="Process Default Language [0x400]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="ImportSDK-3.25.dll" SIZE="525312" CHECKSUM="0x5EE62AE2" BIN_FILE_VERSION="3.25.0.0" BIN_PRODUCT_VERSION="3.25.0.0" PRODUCT_VERSION="3.25 (24.9.2014)" FILE_DESCRIPTION="Import SDK dll" COMPANY_NAME="Tekla Corporation" PRODUCT_NAME="ImportSDK" FILE_VERSION="3.25" ORIGINAL_FILENAME="ImportSDK.dll" INTERNAL_NAME="ImportSDK" LEGAL_COPYRIGHT="Copyright © Tekla Corporation 2014" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8D02D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.25.0.0" UPTO_BIN_PRODUCT_VERSION="3.25.0.0" LINK_DATE="09/24/2014 10:42:04" UPTO_LINK_DATE="09/24/2014 10:42:04" EXPORT_NAME="ImportSDK-3.25.dll" VER_LANGUAGE="Process Default Language [0x400]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="LayOutAPI.dll" SIZE="761344" CHECKSUM="0x582BE41F" BIN_FILE_VERSION="16.1.1449.0" BIN_PRODUCT_VERSION="16.1.1449.0" PRODUCT_VERSION="16.1.1449" FILE_DESCRIPTION="LayOutAPI" COMPANY_NAME="Trimble Navigation Limited" PRODUCT_NAME="SketchUp" FILE_VERSION="16.1.1449" ORIGINAL_FILENAME="LayOutAPI.dll" INTERNAL_NAME="LayOutAPI" LEGAL_COPYRIGHT="(c) 2016 Trimble Navigation Limited" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xC124D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="16.1.1449.0" UPTO_BIN_PRODUCT_VERSION="16.1.1449.0" LINK_DATE="02/24/2016 19:37:39" UPTO_LINK_DATE="02/24/2016 19:37:39" EXPORT_NAME="LayOutAPI.dll" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="LayOutControllers.dll" SIZE="1205760" CHECKSUM="0x390DFB71" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12CD98" LINKER_VERSION="0x0" LINK_DATE="02/24/2016 19:37:31" UPTO_LINK_DATE="02/24/2016 19:37:31" EXPORT_NAME="LayOutControllers.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="LayOutModel.dll" SIZE="6077440" CHECKSUM="0xA5649EBA" BIN_FILE_VERSION="16.1.1449.0" BIN_PRODUCT_VERSION="16.1.1449.0" PRODUCT_VERSION="16.1.1449" FILE_DESCRIPTION="LayOutModel" COMPANY_NAME="Trimble Navigation Limited" PRODUCT_NAME="SketchUp" FILE_VERSION="16.1.1449" ORIGINAL_FILENAME="LayOutModel.dll" INTERNAL_NAME="LayOutModel" LEGAL_COPYRIGHT="(c) 2016 Trimble Navigation Limited" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5CDD16" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="16.1.1449.0" UPTO_BIN_PRODUCT_VERSION="16.1.1449.0" LINK_DATE="02/24/2016 19:37:21" UPTO_LINK_DATE="02/24/2016 19:37:21" EXPORT_NAME="LayOutModel.dll" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="LayOutRTF.dll" SIZE="594432" CHECKSUM="0x6493C943" BIN_FILE_VERSION="16.1.1449.0" BIN_PRODUCT_VERSION="16.1.1449.0" PRODUCT_VERSION="16.1.1449" FILE_DESCRIPTION="LayOutRTF" COMPANY_NAME="Trimble Navigation Limited" PRODUCT_NAME="SketchUp" FILE_VERSION="16.1.1449" ORIGINAL_FILENAME="LayOutRTF.dll" INTERNAL_NAME="LayOutRTF" LEGAL_COPYRIGHT="(c) 2016 Trimble Navigation Limited" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9FA45" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="16.1.1449.0" UPTO_BIN_PRODUCT_VERSION="16.1.1449.0" LINK_DATE="02/24/2016 19:37:08" UPTO_LINK_DATE="02/24/2016 19:37:08" EXPORT_NAME="LayOutRTF.dll" VER_LANGUAGE="English (United States) [0x409]" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="lib3ds_dll.dll" SIZE="103936" CHECKSUM="0x6D78AFF9" MODULE_TYPE="WIN32" PE_CHECKSUM="0x25C65" LINKER_VERSION="0x0" LINK_DATE="03/04/2014 22:11:56" UPTO_LINK_DATE="03/04/2014 22:11:56" EXPORT_NAME="lib3ds_dll.dll" EXE_WRAPPER="0x0" />
<MATCHING_FILE NAME="libogg-0.dll" SIZE="96419" CHECKSUM="0x33EC013" MODULE_TYPE="WIN32" PE_CHECKSUM="0x194E9" LINKER_VERSION="0x0" LINK_DATE="03/18/2014 19:55:26" UPTO_LINK_DATE="03/18/2014 19:55:26" EXPORT_NAME="libogg-0.dll" EXE_WRAPPER="0x0" />
</EXE>
</DATABASE>
The Radeon graphics drivers have issues with 64-bit OpenGL,…
… so you can try uninstalling the 64-bit and running the 32-bit edition.
I can’t see that being the cause of a license error with the 64-bit edition, though. It seems more like it’d be a permissions issue on the “C:/ProgramData” path, where SketchUp writes it’s “.lic” file.
I tried 32-bit version of SketchUp, it has same problem.
TIG
May 15, 2016, 4:51pm
10
When you installed from the SketchUp installer exe… did you right-click on the installer’s icon and use:
“Run as administrator” ?
You need to install SketchUp as THE administrator.
Just ‘being’ AN administrator is NOT sufficient…
