SketchUp Make 2017 Crashing at Start
Installed SketchUp Make 2017 two weeks ago on my Dell Latitude 7480 laptop and it was working fine until yesterday, when it started crashing at start.
Looked up similar posts on this forum and tried to implement many of the numerous solves, including:
  • Updated the graphics driver (Intel(R) HD Graphics 520 - version 21.20.16.4821)
  • Unistalled SU (including Microsoft C++ 2015 redistributable 14.0.24215)
  • Installed .NET 4.4k and the C++ Runtime libraries manually.
  • Re-installed SU.
  • Tried to allocate more memory to the graphics card via BIOS (not possible)
  • Downgraded to SU 2016, then SU 2015, then 2016 32 bits - same issue…
I have also run the SketchUp 2017 Checkup application to understand if there was any hardware/system constraints. All minimum requirements met…
I’m sure this must be a small detail preventing SU to work properly, after all it was working just fine until now. Anyone could point me in the right direction here?
Below is my system info and the log generated by SU Bug Splat.
Thanks!
JM
======== Starting GL ========
WGLUtils::IsExtensionFinderWindowClassRegistered: Class is not registered.
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY1 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY2 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY3 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY4 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY5 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY6 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY7 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY8 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAY9 : Intel(R) HD Graphics 520 : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAYV1 : RDPDD Chained DD : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAYV2 : RDP Encoder Mirror Driver : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \.\DISPLAYV3 : RDP Reflector Display Driver : PT 1
WGLUtils::UtilsState::ctor: Max GPU perf is 1
GlInformation: Starting graphics capabilities tests.
WGLUtils::GetBestPixelFormat: Selected pixel format:
Id: 5 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:0 FF:0
WGLUtils::CreateGLContext: Creating HGLRC with wglCreateContextAttribsARB.
GlInformation: GL renderer information:
GL_VENDOR: Intel
GL_RENDERER: Intel(R) HD Graphics 520
GL_VERSION: 4.4.0 - Build 21.20.16.4821
GlInformation: Compiling UberShader
GlInformation: Compiling OITSimpleDepthPeelLayerShader
GlInformation: Compiling OITSimpleDepthPeelLayerBlendShader
GlInformation: Compiling FaceShaderProgram
GlInformation: Compiling LineShaderProgram
GlInformation: Compiling SaawShaderProgram
GlInformation: All shaders compiled
GlInformation: Creating FBO
FrameBufferObject::Create(): Using renderbuffer storage.
GlInformation: All tests run
Checking GL version:>>4.4.0 - Build 21.20.16.4821<<
OS Version:
CPU Specs:
Installed RAM: 0 MB
Adapter Type:
Adapter Description:
Adapter RAM: 0 MB
Installed Drivers:
Driver Version:
Resolution:
Bits Per Pixel:
Driver:
DPI scale factor: 1
GL_VENDOR: Intel
OpenGL Extensions:
GL_3DFX_texture_compression_FXT1
GL_AMD_depth_clamp_separate
GL_AMD_vertex_shader_layer
GL_AMD_vertex_shader_viewport_index
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_buffer_storage
GL_ARB_cl_event
GL_ARB_clear_buffer_object
GL_ARB_clear_texture
GL_ARB_clip_control
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_compute_shader
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_derivative_control
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_fragment_shader_interlock
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_indirect_parameters
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_post_depth_coverage
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_query_buffer_object
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_seamless_cubemap_per_texture
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_draw_parameters
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_stencil_export
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_barrier
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_polygon_offset_clamp
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shader_framebuffer_fetch
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_compression_s3tc
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_snorm
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback
GL_IBM_texture_mirrored_repeat
GL_INTEL_conservative_rasterization
GL_INTEL_fragment_shader_ordering
GL_INTEL_framebuffer_CMAA
GL_INTEL_map_texture
GL_INTEL_multi_rate_fragment_shader
GL_INTEL_performance_query
GL_KHR_blend_equation_advanced
GL_KHR_blend_equation_advanced_coherent
GL_KHR_debug
GL_KHR_texture_compression_astc_hdr
GL_KHR_texture_compression_astc_ldr
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_primitive_restart
GL_NV_texgen_reflection
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_SUN_multi_draw_arrays
GL_WIN_swap_hint
GL_SHADER_STORAGE_BUFFER_BINDING: 0
GL_MAX_FRAMEBUFFER_WIDTH: 16384
GL_MAX_FRAMEBUFFER_HEIGHT: 16384
GL_MAX_FRAMEBUFFER_LAYERS: 2048
GL_MAX_FRAMEBUFFER_SAMPLES: 16
GL_MAX_RENDERBUFFER_SIZE: 16384
GL_RENDERBUFFER_BINDING: 0
GL_MAX_COMPUTE_UNIFORM_BLOCKS: 14
GL_MAX_COMPUTE_UNIFORM_COMPONENTS: 4096
GL_MAX_COMBINED_COMPUTE_UNIFORM_COMPONENTS: 233472
GL_MAX_COMBINED_FRAGMENT_UNIFORM_COMPONENTS: 233472
GL_MAX_COMBINED_GEOMETRY_UNIFORM_COMPONENTS: 233472
GL_MAX_COMBINED_UNIFORM_BLOCKS: 70
GL_MAX_COMBINED_VERTEX_UNIFORM_COMPONENTS: 233472
GL_MAX_FRAGMENT_UNIFORM_COMPONENTS: 4096
GL_MAX_FRAGMENT_UNIFORM_VECTORS: 1024
GL_MAX_FRAGMENT_UNIFORM_BLOCKS: 14
GL_MAX_GEOMETRY_UNIFORM_BLOCKS: 14
GL_MAX_GEOMETRY_UNIFORM_COMPONENTS: 4096
GL_MAX_UNIFORM_BUFFER_BINDINGS: 84
GL_MAX_UNIFORM_BLOCK_SIZE: 65536
GL_MAX_UNIFORM_LOCATIONS: 4096
GL_MAX_VERTEX_UNIFORM_COMPONENTS: 4096
GL_MAX_VERTEX_UNIFORM_VECTORS: 1024
GL_MAX_VERTEX_UNIFORM_BLOCKS: 14
GL_MAX_TEXTURE_BUFFER_SIZE: 134217728
GL_MAX_TEXTURE_SIZE: 16384
Color buffer bits: 24
Depth buffer bits: 24
InitializeGraphicsPreferencesToDefaults: Starting up.
ComputeDefaultGraphicsSettings: Starting up.
GetChoosableGraphicsSettings: Found the following MSAA options: 0 2 4 8 16
GetChoosableGraphicsSettings: Found the following FF options: 0 1
Id: 16 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:2 FF:0
Id: 28 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:4 FF:0
Id: 41 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:8 FF:0
Id: 53 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:16 FF:0
Id: 10 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:0 FF:1
Id: 35 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:4 FF:1
GetChoosableGraphicsSettings: Found the following choosable MSAA options: 0 2 4 8 16
GetChoosableGraphicsSettings: Found the following choosable FF options: 0 1
ComputeDefaultGraphicsSettings: Selected default settings: MSAA: 0 FF: 1
ComputeDefaultGraphicsSettings: Matched format with settings: MSAA: 0 FF: 1
ComputeDefaultGraphicsSettings: All done.
SaveGraphicsPreferences: Saving graphics preferences: MSAA: 0 FF: 1
InitializeGraphicsPreferencesToDefaults: All done.
File New
File New
CBaseGLView::OnInitialUpdate
Entering CBaseGLView::InitializeOpenGL
WGLViewHelper::InitializeOpenGLForView: Got pixel format with attribs:
HI Did you fix this problem by any chance?
Seems like I have similar, went through same staps as you did.
No changes on my side…:confused:
Start Menu > Control Panel > Programs and Features
Choose “View installed updates” in left column.
Make sure View > Details is chosen in the menu.
When the list is built, if the date ordering is wrong, click the “Installed On” column heading to change the sort order.
The updates will be grouped by product and you’ll need to scroll to check each group …
Was there anything listed here just before you had the startup crashes, but before you began your fix attempts ?
Did you enter any information in the BugSplat! report that the Trimblers could use to look it up in their database ?
