I just started working in SketchUp Make (have been using older versions of SketchUp before, half a year ago), and everything worked okay until the first mistake. Ctrl+Z didn’t work. I checked the keyboard shortcuts, tried adding ctrl+Z and it appeared as “ctrl+Y”, conflicting with Redo. I tried naming the shortcut to “undoz” and it appeared as “undoy”. Simply put, the two keys are switched.
It happens only in SketchUp - other software works fine; as I type this in Firefox now, Z is Z and Y is Y. I never used QWERTZ keyboard on this computer, never used any settings that might suggest that.
The system is Windows 7 Pro, and I’m using the Polish(Programmers) layout, which is same as US standard QWERTY, except with national characters under right alt, e.g. ralt+a = ą. SketchUp Make version 15.3.331 64-bit.
So what the heck?
