I am having a couple issues with SU. If I need a topic for each let me know.
I asked SU Make 2017.1.174 x64 to EXPLODE a group last night. After a while I went to bed. This AM it was still using 12.5% of my CPU but no progress. I force closed the file. The group is one item expanded x10. It happens often but not all the time. I tried again this AM with just that item in the file and it does the same thing. When I force close the file it tells me SU is not responding. I tried it with the object at 1x and it took a while but completed - maybe less than 30 min - I went and had breakfast so I don’t know when it finished.
Orbiting seems to be erratic at times. Occasionally, it will jump so far away from the model that I can’t find it and I have to roll around simply to find the origin then scroll a LONG way to get back to it. I am not sure if scrolling faster when the pointer is not on an object is a “feature” or an issue since it does not do that all the time. Sometimes it moves VERY slow if the pointer is not on an object. I don’t understand??? I have a mouse with a free wheeling function and use that most of the time with SU. That is good and bad, but why is SU unpredictable and what is this instantaneous jumping to the back 40 all about?
Occasionally, when autosaving, it will hang forcing me to force close it. The autosave file that is created is good, but the temp file is still there. It appears like it has trouble closing the temp file. When it works the temp file is closed and it return control to me.
