I use Sketchup quite constantly, and I use Sketchup 2016 Make because I can’t afford pro, and my computer is too cr@p to handle SU 2017. I have no idea why this happens, but after a while of using Sketchup (even on incredibly low poly models), it just freezes, and I can’t end it in task manager (or any similar application), it just says “Cannot end task. Access is denied.”. Even if I use command prompt in admin, and I use taskkill /f, it says:
ERROR: The process “SketchUp.exe” with PID 5840 could not be terminated.
Reason: There is no running instance of the task.
Any ideas why this happens? It happens all the time, and the only way to end the hanging task is to forcefully shut down my computer and turn it on again. It’s so f*cking frustrating.
Any help would be greatly appreciated.
System Specs:
Windows 10 x86-64 (64 bit)
Sketchup 2016 Make x86 (32 bit, even after going from 64 bit to 32 bit it still freezes)
HP Compaq 6730b
2.26GHz dual core Intel CPU
2.25GB RAM (DDR2) (2GB factory plus a random 256MB ram module I found laying around)
Mobile Intel 4 Series Express Chipset Family w/ 128MB dedicated VRAM
DirectX 12 (apparently, after running dxdiag)
OpenGL 2.1
