Hi, I noticed that Sketchup doesn’t remember assigned shortcuts under some keys, for example PgUp/PgDn. It works only until the program restart. Is it a bug?
Does anyone know if Sketchup supports mouse buttons other than LMB, RMB, MMB?
That’s done through the mouse driver interface. Even the conventional three are assigned through the mouse interface.
So how can I assign them in Sketchup?
Can you assign PgUp/PgDn in the Sketchup?
What do you want to assign them to? Did you try that?
Yes, I tried. I want it assigned for example to Camera>Previous or Edit>Delete guidelines.
Looks like Page Down and Page Up are hard coded. If you are going to use buttons on your mouse for these things, you can use some other key strokes that aren’t hard coded. Here I’ve assigned F5 to Camera>Previous and assigned that key stroke to a button on my mouse and it works fine.
I have assigned PgUp/PgDn in mouse software and I use it a lot for websites and rather don’t want to change it. I also have default Forward/Backward functions in other two mouse buttons (9 button mouse), but also don’t want to change them. I just don’t have enough free keys for these two functions for left hand (whole left keyboard site already assigned). Pitty it’s hard coded. For now I just import shortcuts file every time I open SU (with PgUp/PgDn assigned).
It’s strange that you can change hard coded shortcuts like PageUp or Ctrl+V and it works, but they go back to default after restart of the program…
Maybe it can be fixed?
Probably the right thing would be for a message to pop up telling the user that they can’t assign hard-coded shortcuts.
That would require that OS itself be changed, good luck doing that.
