Sketchup details in layout scrap book
just need direction.
I’m drawing details in SketchUp for my scrap book in layout.
I’ll attach my SketchUp file, what’s happening is I create view ports and try sending it all comes over in one viewport, also I have text problem can’t get text to stay where it should stay in SketchUp or layout if I change the scale the text doesn’t change with it in layout
Exterior Footing With Exterior Concrete.skp (2.8 MB)
Share the LayOut file so we can see what you’ve got there, too.
In this particular SketchUp file there appears to be a single detail drawing located a long way from the origin and the scene you have doesn’t save the Camera position which will cause you problems if you use it as a viewport for a scrapbook in LayOut.
The object should be close to the origin and the Camera Position should be saved with the scene.
If you have more than one of these sorts of details in your SketchUp file and want to use the file to create a scrapbook in LO, each detail needs to have it’s own viewport. It would be best to create a scene for each detail in the SU model and then select the appropriate scene for each viewport.
