Hello
Wonder if any one could help, having problems adding text to a layout doc.
I add text to a drawing in layout.
I leave layout and go in to SketchUp to make a change.
I return to the layout doc and the text / image has moved, I then have to start over again,
I try and lock the layer but then find I can’t write over the plan.
If you aren’t creating scenes in SketchUp to use for the viewports in LayOut, the viewports are set up to use the Last saved SketchUp view. When you go back to SketchUp to make an edit you invariably change the view by orbiting, panning, or zooming. When you update the reference in LayOut, it updates to reflect the view as it was last saved in the SketchUp file. It’s no wonder your model is moving under the dimensions and labels.
So yes, absolutely I would recommend that you create scenes in SketchUp to use for the viewports in LayOut. That’s the way it’s supposed to be done.
