Sketchup crashing with big ifc files
I work with quite large IFC files of houses for interior design. They are usually around 80-100MB and they work fine. However my lastest one is 167MB after optimising it and it either won’t input into sketch up or it crashes (not responding) once imported and is unusable.
Is this an issue with my graphics card? GeForce RTX 3050? Or can I work around this?
Thanks.
Is the 3D IFC model oriented far from the zero point / origin?
This can explain an unusable model.
In that case it has nothing to do with your graphics card.
If you don’t need the info attached to the Ifc model, have you tried to import it to Trimble Connect and export it again as TrimBim?
