Help on reducing file size
Hello there,
I am currently having a sketchup file for 130mb and I try to export to IFC, I could not. The export was successful but there is no IFC files. I use this for my dialux so I try to import to 3ds the files when exported is 1.6g. Any masters here can assist?
If you share the file we could check what can be done. You must use wetransfer, Dropbox or any other platform and share the link to download your file.
Thanks for your response but this is a PNC sketchup for a VIP house in my country. So I am unable to share. Really appreciate on your reply.
If you want you can share it with mi via private message, otherwise the only advice I could give you is to install the plugin CleanUp 3 and let it run, it will probably take a lot of time given the size of the file.
Hello Francis, I will try to install the CLeanup 3 plugin first. I really appreciate your prompt reply and thanks again one more time.
You´re welcome, hope it works for you.
