sketchup crashed the last time it loaded extensions. continue to load extensions?
This problem occurs repeatedly, and you can only skip loading extensions,
After skipping the extension program and entering the software, the extension program cannot be used
colin
2
You may need to go through your plugins folder, and remove all non standard items, then add back in others, until you get the crash again.
For Mac the extensions, most are in this folder:
~/Library/Application Support/SketchUp 2020/SketchUp/Plugins
Some may be here:
You can go into Finder, and use the Go menu, Go to Folder, then paste in the text I gave.
If you want, you could tell us some of the extension you’re using, and one of them may stand out as being not compatible with 2020.
I went through the folder, none of them were established by me, in addition, if I click skip, its will run, but, I can’t install any .rbz file.
colin
4
Another file to try deleting is this one:
~/Library/Preferences/com.sketchup.SketchUp.2021.plist
I have got this problem too, and tried to your suggestion for this, but it doesn’t work…so I need go down a old version for my job…
hello, i have the same problem. any solution to this?
I had the same issue if anyone is wondering deleting this worked!
