Since I’ve updated my operating system to macOS 15.2 (sequoia). I get the following error “SketchUp crashed the last time it loaded extensions. Continue to load extensions?” every time I open SketchUp 2024. The only way I use it is loading without extensions. Any insights or a workaround?
load without extensions. then activate a couple and check if they crash. and so on.
it’s a general solution when SU crashes due to extensions, it allows you to pinpoint the one / ones that are causing trouble.
it could be a specific extension, or the way it interacts with the new macOS.
Good idea, but I uninstalled all of them and I’m still getting the same error.
I recently had a problem with an extension too but when I opened SU without loading extensions, I had no extensions in my Extension Manager to turn off. No extensions were listed. So, it confuses me that you seem to say you were able to uninstall all your extensions even after opening without loading extensions?
Reguardless, I was able to fix my issue by opening SU without loading extensions then install the extension that was causing the crash then immediately uninstall the extension. Then quit and reopen with all extensions loaded and everything was normal again.
