Hi, I installed the trial version, but it won’t let me run the program. I get that error. I will tell you everything I already did.
-Remove the program more than 4 times
-repair the program through the installer
-update windows
-Delete all sketchup folders (also roaming appdata, etc.)
-format the entire PC and load new windows
-install Windows version 19xx and 18xx
-installation and program as administrator
-Add the ## NOTRIAL parameter in the .lic file
-I gave SketchUp folder permission to “allow everything” for all users
-Remove all Sketchup records in Windows “local_machine”
-disable “realtek hd” from task manager
-This happens with the 2019 and 2020 version, but I got an old file from 2018 that works well, maybe this information will serve
I don’t know what to do anymore and I need help to work, can you tell me what else should I do? I saw many threads with the same problem and no one gives a solution, thanks and hope you are well
