SketchUp Bugsplat on exit with RTX 5070
SketchUp 2026 BugSplat on Exit (RTX 5070 System)
UPDATE
:+1: Bottom line
  • Your PC is solid
  • Your GPU is working correctly
  • SketchUp is using the newest rendering path (DX12)
  • Crash happens during cleanup, not use
:backhand_index_pointing_right: That’s a software compatibility issue
I’m experiencing a consistent BugSplat crash when closing SketchUp 2026 on a new system. The crash only occurs on exit. SketchUp otherwise runs normally.
System:
  • GPU: NVIDIA GeForce RTX 5070
  • CPU: Intel Core Ultra 7 265F
  • RAM: 32 GB
  • Drivers tested: latest NVIDIA Game Ready and Studio (clean install)
Behavior:
  • SketchUp opens and runs fine
  • Modeling, orbiting, and saving all work normally
  • Files save successfully
  • Crash occurs only when exiting SketchUp
  • Happens even with a brand new blank model (simple box test)
  • Layout closes normally with no issues
  • No system-wide instability or graphical glitches outside SketchUp
Graphics Settings:
  • Using Classic Graphics Engine
  • OpenGL 4.6 (NVIDIA 595.79)
  • No user-installed plugins (only default SketchUp extensions)
Logs:
  • GPU initializes correctly (RTX 5070 detected, shaders compile successfully)
  • No errors during startup or rendering
  • BugSplat logs show an unhandled exception during shutdown and successful crash report submission (minidump generated)
Summary:
This appears to be a SketchUp 2026 crash occurring during the shutdown/cleanup phase rather than during modeling or rendering. Given that everything else functions normally, it may be related to compatibility between SketchUp 2026 and newer RTX 50-series GPUs or current NVIDIA drivers.
Have you sent in the Bugsplats with your email address? If so @colin can look them up.
We have fixed some cases where a crash would happen while SketchUp was closing. If you are already on 2026.1.2, then there may be more fixes in the next update we do. I can’t yet say when that will appear.
I sent that pc back and replaced it with a RTX 5080 machine with a non AmD board. I think NVIDIA was not acknowledging fully the 5070 could have GPU motherboard mismatches. The 5080 works great on the new board/machine. That is the first time I ever had trouble like that in 20 years of using SketchUp and I think it was just perfect storm of several little problems emerging into a big one :slight_smile:
