"Sketchup application has stopped working"
Hi,
Sketchup stops after using it for few minutes. please help me.
I can’t work like this :sob:
Did you install it correctly using Run as administrator?
Which version of SketchUp? You profile is unclear. Does it crash? Does it create a Bug Splat report? Are you sending the Bug Splat reports? If you want help, give us some useful information.
Yes, I did.
2017
well. It shows me this then shuts down :sweat_smile:
What plugins do you have installed?
Hi Dear
I Have the same problem and same error message. I Use VRay Plugin.
Anybody can help me?
Try disabling the Vray extension and see if that changes the behavior.
THX
But I Need VRay and This error appear when i am rendering with VRay. not alway but sometimes.
I understand that you want to use Vray. Since this problem occurs when you are using it, try disabling the plugin and see if the problem goes away. If it does, the problem is most likely with Vray and you’ll need to contact them for support.
