Sketchup 2025 pro materials issues
Hi
So far I’m liking the changes in the new version, but have hit a stumbling block.
When using perforated metal the texture does not show up. I get a wire frame only. I have environments on and it works fine with other metals as in attached screenshots.
Similar issue with glass, just a wire frame.
I also have Sketchup Go on iPad and in the demo model of the dance centre there is a reflective sky glass. This material has an opacity of 41%, yet if I edit any material to change its opacity, it becomes transparent with any value less than 100.
Any ideas on this please?
Thanks
Nick
This is a known bug in DirectX 12 support of your graphics card driver. Try if updating it would help. Download a newer driver from the AMD website and install it.
Thanks for your reply. I have updated to the latest driver but still no luck. Not sure how else to resolve it
You can try if switching to the Classic graphic engine solves the transparency problem, but you will then have to do without the new display features like Ambient Occlusion, Photoreal textures and Environments. When changing graphics options, you must restart SketchUp for them to take effect.
Another option will be to use a suitable graphics card that supports DirectX correctly.
FWIW, this is what I get with the material shown. This is with an Nvidia graphics card.
Thank you both. Yes opacity is ok with classic engine, but hardly worth the move over to 2025. Looks like another situation where hardware needs upgrading to support software changes. Working on an inherited PC at work which was supposed to be good CGI/modelling. Not the best advice given, should stick with Nvidia.
This topic was automatically closed after 186 days. New replies are no longer allowed.
