SketchUp 2022 continuous crashes Macbook Pro M1 Ventura
No matter what I try, I’m getting continuous crashes of sketchup on my macbook pro with an m1. I’ve done many reinstalls, tried different versions, 2020, 2021, 2022 (currently back to this), running with rosetta, not getting any bug splash reports. Just crashes, causing me to have to force quit.
I followed online forum advice to run from terminal to show all processes till it crashes:
Here’s what my terminal shows, until the program decides to just stop working:
Last login: Mon Jan 9 08:00:58 on console
/Applications/SketchUp\ 2022/SketchUp.app/Contents/MacOS/SketchUp ; exit;
cameronobrien@Camerons-MBP ~ % /Applications/SketchUp\ 2022/SketchUp.app/Contents/MacOS/SketchUp ; exit;
2023-01-09 08:15:27.605 SketchUp[1877:27677] Initializing Bugsplat
objc[1877]: Class SkpTimerCaller is implemented in both /Applications/SketchUp 2022/SketchUp.app/Contents/MacOS/SketchUp (0x102e782c8) and /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/LayOutAPI.framework/Versions/A/Libraries/libSketchUpViewerAPI.dylib (0x122a55f38). One of the two will be used. Which one is undefined.
objc[1877]: Class SKTextPath is implemented in both /Applications/SketchUp 2022/SketchUp.app/Contents/MacOS/SketchUp (0x102e78340) and /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/LayOutAPI.framework/Versions/A/Libraries/libSketchUpViewerAPI.dylib (0x122a55fb0). One of the two will be used. Which one is undefined.
objc[1877]: Class SKTextPath is implemented in both /Applications/SketchUp 2022/SketchUp.app/Contents/MacOS/SketchUp (0x102e78340) and /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/SketchUpAPI (0x116a85b40). One of the two will be used. Which one is undefined.
2023-01-09 08:15:28.163 SketchUp[1877:27677] INFO: Start CrashManager processing
2023-01-09 08:15:30.165 SketchUp[1877:27677] [HockeySDK] -[BITCrashManager invokeDelayedProcessing]/974 [HockeySDK] WARNING: Another exception handler was added. If this invokes any kind exit() after processing the exception, which causes any subsequent error handler not to be invoked, these crashes will NOT be reported to HockeyApp!
[0109/081531.704634:INFO:CONSOLE(4172)] “Error accessing file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/…/en.lproj//welcomescreen/en.json–[object ProgressEvent]”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4172)
[0109/081531.704714:INFO:CONSOLE(4357)] “Unable to find resource file for language en”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4357)
[0109/081531.704748:INFO:CONSOLE(4358)] “In location file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/…/en.lproj//welcomescreen/en.json”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4358)
[0109/081531.721758:INFO:CONSOLE(10397)] “Uncaught (in promise) NavigationDuplicated: Navigating to current location (”/trial_notification") is not allowed", source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (10397)
[0109/081531.775431:INFO:CONSOLE(22)] “Munchkin.init(”%s") options: 645-COJ-341 [object Object]", source: https://munchkin.marketo.net/162/munchkin.js (22)
2023-01-09 08:16:05.217 SketchUp[1877:27677] Cannot find plugin in /Applications/SketchUp 2022/SketchUp.app/Contents/PlugIns/DEMImporter.plugin
2023-01-09 08:16:05.217 SketchUp[1877:27677] Cannot find plugin in /Applications/SketchUp 2022/SketchUp.app/Contents/PlugIns/IfcImporter.plugin
2023-01-09 08:16:05.270 SketchUp[1877:27677] Cannot find plugin in /Applications/SketchUp 2022/SketchUp.app/Contents/PlugIns/IfcExporter.plugin
UNSUPPORTED (log once): POSSIBLE ISSUE: unit 0 GLD_TEXTURE_INDEX_2D is unloadable and bound to sampler type (Float) - using zero texture because texture unloadable
2023-01-09 08:16:18.371 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:16:29.643 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:16:57.919 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:17:06.474 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:17:15.944 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:17:25.338 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:17:32.752 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:17:40.295 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:17:42.322 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:18:06.887 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:18:08.794 SketchUp[1877:27677] action selectDollyTool:
2023-01-09 08:18:12.041 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:18:15.371 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:18:22.512 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:18:27.634 SketchUp[1877:27677] action selectDollyTool:
2023-01-09 08:18:35.834 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:18:52.716 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:18:54.409 SketchUp[1877:27677] action selectDollyTool:
2023-01-09 08:18:58.178 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:19:04.139 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:19:13.191 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:19:55.196 SketchUp[1877:27677] action selectDollyTool:
2023-01-09 08:19:56.883 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:20:00.812 SketchUp[1877:27677] action selectMoveTool:
2023-01-09 08:20:20.458 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:20:25.524 SketchUp[1877:27677] action selectOrbitTool:
2023-01-09 08:20:29.205 SketchUp[1877:27677] action selectMoveTool:
It will even crash chrome after a while trying the free online app. I’m not using any materials or items to slow my files, it’s a simple shower with wireframes and framing. At this point it seems pointless to even pay to buy the subscription, if it just crashes every 1-5 minutes after opening.
This topic was automatically closed after 186 days. New replies are no longer allowed.
