Sketchup 2021 + V ray on Macbook pro M1
Hi the community, I’m Nathalie,
I’m thinking about changing my MacBook Pro half 2012 for the new Macbook pro M1 to be able to use Vray on SketchUp 2021 (I’m actually on SketchUp pro 2018). If you have tested this, could you please tell me , how does the new graphic card on M1 perform VS the dedicated graphic card like Nvidia GTX 1070…? (sorry for my english It’s been a long time I didn’t write/speak)…
Thanks by advance…
The M1 has an integrated GPU so it probably won’t be used by Vray. But the CPU is a beast and can hold it’s own against most CPU based rendering. That being said, it won’t compare well to a PC laptop equipped with a dedicated NVIDIA gpu.
I understand that currently V-ray doesn’t work on M1 Macs. Currently GPU rendering is for Nvidia cards only (=Windows only)
Is that true for AMD as well, that if you have a Mac from the last 8 years, or a PC that happens to have an AMD GPU, you only get software rendering?
Chaos released a new vray for M1 a month ago and apparently it works well.
Yes, it works. One more thing, though, I had to download and install the license server seperately, via the System Preference > Security and Privacy > Launch
This took me to the terminal, where I had to enter my password for the Mac-Account.
Now, it’s running.
@Colin Yes Cuda cores only, so NVIDIA it is.
I read that was dropped by Nvidia as well.
don’t throw away older GPU’s yet. It should still work. It also works with RTX:
In time, Microsoft will come with a working ARM chip, as well, maybe with some NVIDIA gens
Thank you all!
So what I understood from your contributions, it’s that I can buy the macbook pro M1 and use without big issues Sketchup with V Ray…
I that right?
OK - so I landed on an outdated help page…
There is so little info about this on the internet right now and most is hard to find at that. My best source of info on the subject has been this site actually, along with some YouTube videos I’ve seen. Even chaos doesn’t really mention it as you’ve seen, which is quite odd to me.
What they said on the page I found was that rendering itself works but, for instance, the Asset editor doesn’t. So you cannot really set up renders.
And in the chaos forums they said they’ve addressed that too in the last release.
Hi all
I asked this questions direct to chaos just the other week :
Hi Jo,
We have the first renders done with V-Ray native for M1 chip. Official release is expected in the first half of this year but we still don’t have a release date.
We did some changes to the standard V-Ray and it works with SketchUp 2021 on M1 chip through Rosetta 2 emulation.
Best Regards,
Alexander Milanov
Chaos Technical Support
-___________________
Hi Alexander
Thanks for getting back to me
So would you say hold off buying the M1 mac until later on when you have it ready for the M1 Mac ?
Best
Jo
Hi Jo,
It depends - the current version works too and you can always switch to the native V-Ray later.
If you are not in a rush to get it now you can wait for the native version to come out.
Best Regards,
Alexander Milanov
-___________
In short this is direct from chaos them self
V- ray does now work on an m1 Mac through Rosetta 2 but they do have a native version on the way first half of this year . So happy days :+1: guess it will come out around june when ape do there second event .
Hi guys,
I’m definitely a pro and does not understand the requirements needed exactly to run Sketchup Pro and Vray on a mac.
My settings are:
  • Intel Iris Plus Graphics 645 1536 MB
  • Macbook pro 2019
  • Big Sur 11.4
When I’m trying to select material into the V-ray asset editor, it says that the materials are not available for Vray (but I have all the material available for Sketchup).
I click on the button to download them, then I wait with the message “checking for updated library files”.
And when I try to download it “something went wrong while loading the library, we were unable to determine if the content you have is up to date with the latest version”.
I’m running the trial version of Vray so I’m sure I have the last version available.
Someone got the same problem or have an idea of what I should do to make it work?
Thank you in advance for your help!
Something might have gone wrong when installing, one has to give permissions for the app to have access to folders and such.
Both SketchUp and the various V-Ray’s installs.
Reinstalling both might work.
Will SketchUp Pro 2021 PL + V-Ray 5 and rendering work with MacBook Pro 13 with Apple M1 processor - 8-core CPU + 8-core GPU / 16GB RAM / 1TB SSD / 2 x Thunderbolt / Space Gray ?
