Hello, I’ve just imported a location into Sketchup 2020 for the first time. I have unlocked both the Location Snapshot and Location Terrain in the Outliner. The snapshot works as it did in SU 2019. The location terrain is light grey. If I click on it a blue bounding box appears but no visible terrain. It’'s not in italics like a hidden object. I also tried to import land with a different model in a different file and got the same result. Please advise.
You could toggle the tag visibility on and off in the Tags panel. If you turn on the visibility for both tags in the Tags panel, you can turn them on and off in the Outliner.
The visibility thing in Outliner is a Hide/Unhide thing which is different from making tags visible or invisible.
