SketchUp 2017 Measurement Box
Can anyone tell me how (or even if) I can make the Measurement box in the lower right corner LARGER?
I’ve got a pair of 24in monitors and it’s just small! It seems to be part of the lower status bar.
Thanks in advance.
Probably not possible.
There is a toolbar ‘Measurements’ which you can activate [and unlock and relocate etc] which opens instead of the box in the bottom status-bar, but the max length of its text box is actually smaller than the status-bar box - so not very much use…
:thinking:
I don’t use Windows much now, but I wonder whether you have tried changin the DPI scaling in Display properties to force text and the GUI bigger?
IIRC SU can work with scaling up to 150% - it’s getting better at scaling the interface to the screen resolution and size, but with limitations still.
If SketchUp (or any other program) doesn’t have a setting to make text larger, you could use the operating system’s accessibility features to zoom in. This isn’t as good as the program having a setting, but it might be a good enough workaround.
On Windows, turn it on here:
Start Menu → PC Settings → Ease of Access → Magnifier
OR
Control Panel → Ease of Access Centre
Once on, use the windows key with ‘+’ or ‘-’ keys to zoom in or out. Windows + ESC to turn it off. ctrl + alt + scroll wheel
On my Mac, I have ⌘ + scroll wheel available to zoom in at any time in any program. Set it up in:
System Preferences / Accessibility / Zoom.
Thanks, I finally figured this out. And undocking the measurement box from the lower status bar is more in line with what I wanted anyway. I actually put it up in an upper corner which makes things easier for me.
