After a NEW install Sketch-Up Pro 2017 or 2018 program will NOT open at all.
I’ve done ALL and others have stated in there post Administrator installs updates Video drivers from Intel removed Microsoft Visual C++ etc.
Lenovo T470 - Intel v620 - Not working
Lenovo Carbon X1 - Intel v520 - Not working
Lenovo - P50 - nVidia Quadro M2000M - Works Fine.
1.) incompatible graphics card driver, i.e. OpenGL support not compliant => update
2.) incompatible plugins/extensions => udpate/disable*
3.) Win: wrong or missing prerequisites (= MS runtime libraries) => install SU again by “r-click > Run as Admin” or install the libs manually one by one (point #5).
*disable: start SU from the command line with the “\DisableRubyAPI” flag… or rename/move the plugins folder.
Assuming all of the previously mentioned ‘prerequisites’ have been met without success…
You original post mentions ‘administrator’ - and is at best ambiguous.
For the avoidance of doubt, SketchUp must be installed properly to avoid unpredictable issues with file/folder permissions etc…
Even if you [as your normal Windows-user] have admin-powers, OR are even the main system administrator [not normally recommended], the only proper way to install [or repair] SketchUp is as follows.
Log in as your normal Windows user-account.
If SketchUp is open then close it.
Find the SketchUp installer’s exe file [probably in your Downloads folder ?]
Select its icon, right-click > context-menu > “Run as administrator”…
When prompted choose “Repair” [this should not adversely affect custom settings or plugins etc].
Note that if that still doesn’t work choose “Uninstall”, then immediately after that competes repeat, choosing “Install”.
Note that for a fresh installation requires you to choose “Install”.
When it completes try restarting SketchUp…
On newer PCs installing any complex app like SketchUp must be done using “Run as administrator”.
Doing it any other way causes unpredictable issues.
Never double-click the installer’s exe file’s icon to Run it - it is not equivalent to doing it properly - even if you have admin-powers !
