@Guy Thanks for clearing that up, I was pretty sure it worked fine before, but I will uninstall and reinstall down to 3.0.0072.
@Guy I seem to have missed downloading the 3.0.0072 version, only have 3.0.0036 and 3.0.0078 (which doesnât work for me) downloaded. Can you please âhook me upâ?
@Guy helped me out with the file, thanks a million!
Dear Skalp user,
This year on December 12 and 13 there will be another 3D Basecamp Benelux for all SketchUp users and 3D fanatics.
Come to the Evoluon in Eindhoven (NL) and experience your best 3D experience ever with exciting keynotes and workshops.
Use the coupon code SkalpDiscount25 to get 25% discount on your 3DBasecamp tickets
On Thursday afternoon the Skalp team wil give a 3 hour workshop .
You will get the chance to get a personal lesson from the developers of Skalp.
We start with the basics of Skalp down to the smallest details of our extension.
We will explain in detail how you can create professional drawings of your SketchUp projects with almost no effort.
Not only do we explain how to use Skalp in combination with LayOut , but also how to create a workflow with AutoCAD .
During and afterwards you will have the opportunity to ask questions to the developers of Skalp.
We hope to see you in our workshop.
The Skalp Team
Looking forward to see you guys there!
Together with the new SketchUp 2020 we released the new Skalp 2020 Beta version for SketchUp 2020.
This new version has some very nice new features:
- Support SketchUp 2020.
- Toolbar icon for export to DXF/DWG.
- Toolbar icon for export to LayOut.
- Graphical material selector.
- Paint sections in the model with the new Skalp Paint Tool.
- You can now use a Skalp material from a Library without importing the complete library.
- You can now Export Skalp materials from the new Paint Tool directly to a library.
- SketchUp linestyles are now supported in the forward lines of the Skalp DWG/DXF export.
Also we updated our naming to the new SketchUp naming:
- âBy Layerâ is renamed to âBy Tagâ
- Skalp âTagâ is renamed to âLabelâ.
The new SketchUp feature to hide objects in scenes gave us the opportunity to reduce the use of Skalp tags (layers). We donât create anymore a new tag (layer) for every scene or sectionplane.
We also changed the default Skalp rule setting to âBy Tagâ followed by âBy Objectâ for easier use with the new Skalp Paint Tool.
The release is a BETA version! If you find any error, bug or bugsplat please contact us at support@skalp4sketchup.com
You can download this Skalp version from our download page
If your Skalp maintenance isnât expired you can use this Skalp 2020 version without any cost by using your Skalp activation code. Installing Skalp on multiple SketchUp versions on the same computer count only as one activation! If your maintenance contract has expired, you can still use your license key to activate Skalp. However, you will then be redirected to renew your maintenance contract.
The Skalp Team
Hi Guy
I like using skalp but one issue I canât get around is that the section line of the previous view shows in the non section views. The skalp layer cannot be turned off unless you turn off skalp completely. So I end up having to PDF drawings from layout that have sections, then go back to sketch up and turn off skalp and regenerate all non section views and print, update layout, and print separately and compile the drawing set in PDF. This is time consuming. Is there something I am doing wrong ? Is there any work around for this. Hopefully you can see this on the attached image.
Thanks S
Try turning off âï»żSkalp Live Sectionâ layer⊠Thatâs where Skalp stores live section cuts. I suggest you use âSave to sceneâ option in Skalp which will create layers for each section. Then you can use those instead of Skalp live layer on your scenesâŠ
Hey there Jure,
Iâm looking to get a trial of Skalp for myself and a customer. Iâve tried emailing support but didnât get a response. Could you please PM me here? Thanks.
Sorry I missed your reply⊠Does this link not work for you? http://download.skalp4sketchup.com/downloads/latest/
Anyways I think you might be better off using Curic Section instead of Skalp. I have switched now from Skalp to Curic Section since it gives me more control and more features.
Make sure to check my âunofficialâ Curic Section manual because there are couple of bugs that you need to know how to work around, otherwise you might get stuckâŠ
Hi Jure,
I got that download thanks. I had a client that was looking for this solution but he has deferred use of SU for another time or maybe permanently. I was able to supply the link but he had made his decision by that point. Maybe in the future I will get to it. Thanks again.
Thanks very much for sharing your manual - itâs much appreciated ![]()
