Shortcuts in SU web are not translating to french
Ok, I pretty much never use SU web, and when I do, I don’t use shortcuts. so I didn’t notice this until today.
My SU for web is in french, so is my keyboard (AZERTY), but the shortcuts are in QWERTY mode :
if I hoover on the circle tool, it tells me to press C as a shortcut. Fine.
if I hoover on the rotation tool, it tells me Q however if I press Q, I get the 2 point arc tool.
if I hoover on the 2 point arc tool, it tells A, and when I press A I get the rotate.
Same with move tool, it says M, but I have to press the ,? key.
thing is, on an AZERTY keyboard, some things are switched compared to a QWERTY : A and Q, M and ,?, Z and W
SU for web shows the proper shortcut in the hint, but expects me to use a QWERTY keyboard.
Tried in Safari, same thing. it expects me to be using a QWERTY layout.
Anyone with an AZERTY layout + machine can try and confirm ?
edit : tried on my PC, same deal. app thinks don’t see it as AZERTY
It does seem to read the keyboard code and not the letter you pressed.
@marwanobeidat I don’t see a bug report that exactly matches this issue. The problem, doesn’t happen with the desktop version of SketchUp.
yep. I guess the german keyboard might have this issue too on one or two key, since they swap Z and Y.
