Shadows obscure material... sometimes
Hi!
Could someone help me fix this little settings issue i have please. When i turn on shadows some of my material textures are obscured by the shadow, while others aren’t. See the attached screen shots. I’m not sure whether this is the material setting or the view setting but maybe someone can advise please?!
thanks in advance
Paul
It looks like the ground plane and your floor are fighting.
Go to the shadows window and turn off ‘on ground’ or whatever that setting is.
If you need them on the ground then you need to move your model up a so the two surfaces are separated from each other, or your floor is higher than the ground plane.
Ha! of course.. Doh!
I made an extra ‘ground floor’ a few days ago so i could have one with textures, and one all in white, for use in different views.
I’d forgotten about that and left them both turned on.
Thanks for quick accurate response!
Solved!
