I have a floor plan (ala Nick Sonder floor plans) that is showing some very strange behavior. I have assigned some colors/materials to some faces representing the floors. However, hen I view the plan WITH SHADOWS ON, it appears that some of the materials have disappeared but that room’s shadows show the proper color. When I turn SHADOWS OFF, the floor materials appear seemingly fine.
I have attached two screenshots showing the behavior.
Can you post the model here on the forum to troubleshoot? It looks like you have colors and materials mixed and the colors only exhibit the behavior you describe. Are all the materials stock or did you import them?
A dumb question: do you have Ground enabled in your style, and is the ground coplanar with the floors? And is SketchUp set to cast shadows on the ground?
When I opened your file and looked at the shadow settings I see that you have the Light and Dark sliders set way to the right. Your materials are disappearing because the settings you are using are washing them out.
If you play with the shadow settings you will also discover that the shadows in the pale salmon area are actually those cast on the ground that are showing through because that material is translucent. If you turn off On Faces, they will remain but the others will disappear!
