Shadows below axis showing up as grey on axis
Hello,
I would like to know from the engineers at sketchup if there is a solution to have shadows land normally even if the surface and the component are below base axis. For instance: one part of the landscape is on the base access and then the hill descends to a lower portion with trees that is below base axis. the shadows will appear like blank grey shadows on axis rather than where the shadow would end up, on the landscape, if this area was not below axis. If you could solve this for me that would be great.
Regards,
Ryan Crompton
It was solved years ago. Turn off On Ground in the Shadows panel and they won’t show up on the ground plane.
shadows
Here it is in SketchUp 3.1 from 2003.
shadows 3
